Proud Jeep Owner
Discussion in 'New Members' started by Jeep V8, Mar 1, 2012.
  1. Mar 1, 2012 at 6:28 PM
    Jeep V8
    Jeep V8 [OP] Member
    Mandy
    But my Jeep may crap out soon and am curious about a Toyota SUV or Truck. Any advice?
  2. Mar 1, 2012 at 6:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    What are you wanting this vehicle for primarily?
    I jeep is a very capable rig stock, as you already know.
    Our trucks make for a great combo rig, good on trails and as Daily Drivers.
    Can certainly tow more with the truck.
    Give us some specifics and we may be able to help you out better.
  3. Mar 1, 2012 at 6:31 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    2012 Tacoma V6 5spd 4x4 TRD Off-Road
  4. Mar 1, 2012 at 6:33 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    The title and thread kinda contrast eachother..... Go with the taco their worth it.
  5. Mar 1, 2012 at 7:09 PM
    Jeep V8
    Jeep V8 [OP] Member
    Mandy
    What can I say, I am indecisive...
    Have a lot of sports gear: skis, bikes. Don't want them getting stolen.
  6. Mar 1, 2012 at 7:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    The 4runner is a very nice and capable vehicle. You could get a truck and put a shell on it. Depending on how hard you wheel would be the deciding factor in my opinion.
  7. Mar 2, 2012 at 12:20 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Do you want to buy new or used?
    Sounds like a Tacoma Double Cab Long Bed would be the best for you. You can always add a camper to protect your sports gear.
  8. Mar 2, 2012 at 12:30 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    True, the First Gen frames last at least 10 years before they rust through.
    Edit: We joke but both Generations have their pros and cons, I don't think you can go wrong either way.
  9. Mar 2, 2012 at 9:23 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Long beds are not available with the TRD Off Road Package as well as being too long for trails that Jeeps are used to. The Off Road package has additional traction that no other Tacoma has (Rear locking differential and on 2009 or newer Tacomas the A-TRAC which is like having automatic front and rear lockers when in low range). If not a Tacoma than an FJ Cruiser or 4Runner...? I was a former Jeep owner, and the difference between Jeep and Toyota is night and day... quality parts and build. You don't need to save up for repairs on a Toyota like you do on a JEEP (Just Empty Every Pocket) vehicle.
  10. Mar 2, 2012 at 8:14 PM
    Jeep V8
    Jeep V8 [OP] Member
    Mandy
    Thanks for the replies. That is especially helpful to hear from a former jeep owner.
    David, what kind of Jeep did you have?
    What are the pros and cons of an FJ cruiser vs the 4runner?
  11. Mar 2, 2012 at 8:15 PM
    Jeep V8
    Jeep V8 [OP] Member
    Mandy
    Also I have a daughter, so I would need a car seat in the back for the day to day grind.
  12. Mar 2, 2012 at 8:20 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Runner would have more room. OOB, FJ is probably more capable off-road. Definitely has more off-road niceties than the Runner from the factory.
  13. Mar 3, 2012 at 9:57 AM
    David K
    It was a 1975-1/2 Cherokee Chief.... when the Chief package first came out (using the Jeep J-10 truck axles for wider track vs. the Wagoneer axles of the standard Cherokee... and had the wider wheel wells... Levi seats, 401 V-8, Quadra Trac full time 4WD, 2 speed transfer case and center differential locker). Almost everything failed in the 2 years I owned it (water pump, rear widow motor, window handle, radiator, automatic transmission was a GM Turbo 400 and it needed a rebuild, low range ... all in two years on a new vehicle (any wonder AMC failed?)!
    My wife had a '79 CJ-5 Renegade with the 304 V-8... and hers was excellent, she had it for 19 years until her son flipped it on the freeway because the tranny or ? 'locked up' and it endo'd! Now we both have Toyotas, and no more problems with cars!
    As for the 4Runner vs. an FJ Cruiser... go to some Toyota dealers and see which you like... just make sure the one you get has A-TRAC (as not all models do)!
  14. Mar 3, 2012 at 6:49 PM
    mikethemug
    mikethemug Member
    mike
    cincinnati OH
    dbl cab 4x4
    I'm a Jeep owner too(96 cherokee 4.0 str8 6). I think I have a strong 3 - 5 years left in it but I need a truck and in my investigations I've found that it's only the Tacoma that qualifies for my needs. 1 question for u Jeep owners turned Tacomaniacs, hows the power comparison - greater, lesser, a little feedback pleeze.
  15. Mar 3, 2012 at 7:04 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I came from a '93 XJ 4x4 4.0L 5sp that I bought new and gave to my dad with 300k+miles. He is still driving it around as a farm vehicle. I went to a 4cyl Access Cab 4x4.
    The Tacoma is a much more finished vehicle. Quieter, ABS/Traction Control/Stability Control/etc, better interior.
    The Cherokee had more power than the 4cyl and felt quicker in every way. I doubt it would be much different than the V6 Tacoma. It also had a smaller turning radius and in general felt more balanced in the snow and off road. I loved that Jeep but I also love the utility of having a pickup.
    Interestingly enough, I had a lifetime average of 21.7mpg in the Jeep and am only a half a mpg above that with the 4cyl Tacoma.
    The Cherokee was just a well balanced vehicle from the weight and power standpoint. Replaced the clutch at 250k and tires every 100k.
  16. Mar 3, 2012 at 7:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    3rd gen runner FTW!
  17. Mar 3, 2012 at 8:20 PM
    Jeep V8
    Jeep V8 [OP] Member
    Mandy
    Thanks for the feed back, I think I will go in and take a look after researching some of those features, like the A-trac.
  18. Mar 3, 2012 at 8:29 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I went from a 97' Jeep (drove it for 10 yrs) to an 06 DCSB Sport. Love it. If I take the Jeep out for a spin on the weekends (still have it), when i get back in my Taco, it feels like i'm driving a cadillac...lol.
  19. Mar 3, 2012 at 8:34 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    I have had 3 jeeps, 1984 CJ7, 2000 Cherokee, 2006 Wrangler Unlimited.
    I like jeeps, that said here is my breakdown
    Tight crawling type trails, Jeep
    Faster Desert type stuff, Tacoma
    On road performance, Tacoma
    Comfort, Tacoma
    Towing, Tacoma
    Hauling, Tacoma
  20. Mar 3, 2012 at 8:43 PM
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    Sounds like a jeep :D
