PRS' 73 Scout II build
Discussion in 'Other Builds' started by PreRunnerSeth, Aug 8, 2010.
  1. Aug 8, 2010 at 4:12 PM
    PreRunnerSeth
    PreRunnerSeth [OP] Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Project 73 Scout II
    Specs:
    Engine: Orignal IH 345Ci 182HP TQ 303Ft/Lbs
    Transmission: Chrysler Torque Flite 3 Speed Automatic
    T-Case: Dana 20 2speed 2:1 Ratio
    Rearend: Dana 44 with Drum brakes
    Frontend: Dana 33 With Drum brakes
    Suspension: Spring under Leaf Springs with shocks
    Wheels/Tires: 31 M/T on 15" steel wheels.
    Body: A little beat, but not a lot of rust (Winter project)
    Plans:
    Engine: Rebuild, Custom built Q-Jet 4bbl carb, New exhaust, electronic ignition.
    Gauges: ISSPro Gauge Conversion
    Transmission: Rebuild, shift kit
    T-Case: Replace and Upgrade to a 3:1 Ratio,
    Front end: Install the Chevy front Dana 44, Pinion angled 8*, re-geared to 4:11, ARB Locker, and set up for spring over conversion, and tapped for High Steer.
    Rear end: Chevy 12 Bolt, Rebuilt, regeared for 4:11, Arb Locker, converted to spring over.
    Suspension: CPT Long Travel Kit, shackle reversal
    Trail Gear: Front and rear bumpers and sliders.
    Wheels/Tires: 35 m/ts on the 15" steelies.
    8/8/2010
    Went and picked it up. It runs pretty well, but has some oil leaks, only drives in 4x4 and transmission wont go into reverse. The body is pretty straight. The winters projects will be to get the body straightened out and primed. Will also be pulling out the rear end. Getting it converted over for spring over, and rebuilt with 4:11s. Will do the ARB when I have more money.
    Pictures (Last Picture is of the Chevy Dana 44 that will get built up for the front later):
  2. Aug 8, 2010 at 4:12 PM
    PreRunnerSeth
    Apex, NC
    Reserved for later use
  3. Aug 8, 2010 at 4:12 PM
    PreRunnerSeth
    Apex, NC
    reserved for later use.
  4. Aug 8, 2010 at 4:14 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I don't see any pics. :notsure:
  5. Aug 8, 2010 at 4:17 PM
    747 function > form
    1st Gen.
    Scouts are sweet...sub'd.:popcorn:
  6. Aug 8, 2010 at 4:21 PM
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
    Pictures!?!?
  7. Aug 8, 2010 at 4:30 PM
    PreRunnerSeth
    Apex, NC
    Impatient!
    They are up now.
  8. Aug 8, 2010 at 4:42 PM
    SACTOWN
    Greg
    Sick!!!
  9. Aug 8, 2010 at 4:49 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    looks like fun
  10. Aug 8, 2010 at 4:59 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Cool corn binder.
  11. Aug 9, 2010 at 7:58 PM
    PreRunnerSeth
    Apex, NC
    08/09/2010
    Today I removed the passenger door and gutted it. It will go over to my friends. There are holes down the side from some molding that was long gone. There are also several holes from various mirrors that had been installed at different times. All these holes will be filled by my friend. In the mean time I will sand and paint the door panel. This thing is all sheet metal! no plastic or cardboard door panel here. This thing is a solid beast.
    This door will need a new regulator because the window wont roll up.
  12. Aug 9, 2010 at 8:05 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
  13. Aug 9, 2010 at 8:09 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    Sweet. I am currently doing a 72. Mine is a little more rough around the edges.
    Doing a frame up restoration.
  14. Aug 9, 2010 at 8:43 PM
    PreRunnerSeth
    Apex, NC
    Nice!
  15. Aug 9, 2010 at 8:48 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    Awesome, I love old scouts. One day hope to build one myself. Keep us posted on the progress. Good luck with it.
  16. Aug 9, 2010 at 11:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    subbed. This is going to be good.
  17. Aug 13, 2010 at 8:30 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    This sounds like an interesting build/project, will stay interested as you continue to work.
    It sounds like you are doing a "rolling" restoration? Or are you going to go ahead and completely tare this ting apart?
    I recently became very interested into IH scouts, especially the 800's of the 60's. Would love to get one and have something to work on a couple of days a week.
    Would love to also "Line-X" it, and make it a good trail truck.
  18. Aug 14, 2010 at 2:01 PM
    PreRunnerSeth
    Apex, NC
    I definitely will not be doing a frame off, But i plan to do the best i can without taking the body off the frame. I plan to line-x/bedliner the interior. Something to think about when line-xing the whole thing, this is already a pretty damn heavy truck. doing a complete line-x will add to the weight.
  19. Aug 14, 2010 at 3:23 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah that's something I'm worried about, it adding a lot of weight. Maybe half way up from the bottom can be Line-X, and the other portion can be paint.
    I'm not sure what the thickness of the metal is, but I'm guessing it's thick. Which is always a good thing, but the weight sucks. I hear these scouts are very solid trucks, sounds good to me!
    Your plan to put Line-X into the interior sounds like a good idea.
  20. Aug 18, 2010 at 6:56 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    moooar pics
