PS Power Window not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Apr 20, 2012.
  1. Apr 20, 2012 at 4:27 AM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    This winter past I passenger side PW stopped working. I thought I blew a fuse. I checked that and the 20a looked fine. I swapped 2 20's around in the fuse panel anyway but it still didn't work. I brought my truck in to Toyota today for regular maintenance and mentioned the window. They said they may not have time to check it as I didn't mention it when I booked the service. Fair enough. If they do have time, it may cost $80 to diagnose because it may or may not be covered under warranty. So I didn't bother to get them to look into it.
    So given the fuse is good, and the window doesn't work from either switch, but the DS window does work, where is a good place to start to diagnose this myself?
    I likely tried to open the window when it was frozen and blew something. The question is what?
    Thanks
  2. Apr 20, 2012 at 4:09 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Everything goes through the main switch from what I remember.
    My windows were problematic and would only work sometimes and or stop working for days on end.
    Pop main window lock button up and down a few times. See if it go stuck closed. Happened to me once.
    Also pull the switches and check the contacts on them. Three of mine had corrosion building up on them and caused most of my problems.
  3. Apr 20, 2012 at 4:35 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Make sure to check the child window lockout button on the driver's side wasn't pressed by accident. Happened to me once and took me a bit to figure out.
  4. Feb 7, 2013 at 2:12 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I know this is an older thread, but I figured I would thank you anyways.
    My passenger side window stopped working. After checking the fuses and figuring that since both switched didn't work and the fuse was good it must be the motor. I was just ready to start pulling the door panel off when I thought I would do a quick search on TW to see if anyone had a similar problem.
    To be honest, since I have a Access cab (and no kids), I didn't even think to checkl the child lockout.
    Sure enough, that's what it was!
    Shawn.
  5. Aug 19, 2014 at 2:22 PM
    Firemediceric
    Firemediceric New Member
    Florida
    2006 Tacoma
    So glad I found this old thread. I would have never guessed to check the child lockout button on my access cab. On my other vehicles the driver's controls will still work the power windows even when the other controls have been locked out. This thread just saved me a lot of headache, swearing and a few thrown tools. I will check that button first thing the next time I let the wife take the truck again, as she's the one that hit it this time.
  6. Aug 19, 2014 at 5:10 PM
    Raylo
    MD, USA
    LOL, that was exactly me when I somehow inadvertently pressed mine whilst installing my remote start/alarm system waaaay back in 2009. I thought I had fooked something up, only to find the child switch after checking things with a multi-meter... and much cursing. But it's still good when we get an easy one.
