PSA - Evap core freezing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fullboogie, Oct 14, 2019.
  1. Oct 14, 2019 at 5:47 PM
    Fullboogie
    Fullboogie [OP] Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Been dealing with this problem for about 2 months. A/C starts out fine, but after a short period the air flow drops dramatically. The fan always seemed to be operating fine at all speeds too.
    Went on a 290 mile trip last week and experienced the same problem, as usual. So I set the A/C controls to outside air, A/C button off, to de-ice the evap core. It didn't work, and what little air was coming out of the vents was still cold. Pulled over to gas up and popped the hood, just to take a look. By chance I saw the damn compressor running. I stuck my head back in the truck to make sure the A/C button was set to "off" and it was, which was really weird. Swapped the A/C relay for the fog light relay, and it cured the problem completely for the rest of the trip to my destination and back.
    Looked at the relay under a magnifying glass and honestly could not see any problem with the contact, so I don't know exactly how it failed. But it obviously did, because it would not allow the compressor to ever cut off or cycle.
    So if you have an evap core freezing problem, try replacing the relay. It may save you some money.
  2. Oct 14, 2019 at 11:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That was a great catch!
    Good work!
