PSA: Heat kills batteries
Discussion in '2nd Gen. Tacomas (2005-2015)' started by finslayer83, Jul 21, 2015.
  1. Jul 21, 2015 at 12:34 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I used to detail for a dealership until I quit and moved on with my life. Let me out this way: the dealerships leave cars sitting
    For months at a time sometimes so batteries can bad pretty easily.
  2. Jul 21, 2015 at 12:36 PM
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Correction: Heat causes batteries to wear faster. Otherwise those of us in Arizona whose trucks see 90F+ almost all year long would be changing batteries every couple months.
    What really did yours in was probably the dealership letting the battery run down before they jumped it to keep it going. Not to mention it was already getting close to the rated life of a standard wet cell car battery at around 3 years.
    Damage/wear to the cell has already been done by the time the battery needs to be "recharged". Standard wet car batteries are not made to be drained and recharged, they're designed to have the maximum amount of cold cranking amps and stay topped up all the time. If you're eating through batteries like this, you need a deep cycle like the Optima Yellow top, which is designed to be drained and then recharged.
  3. Jul 21, 2015 at 12:44 PM
    finslayer83
    finslayer83 [OP] Well-Known Member
    TN
    TRDP 4runner / 01 Taco
    A lot
    Thanks all.
    Just for reference - if the alternator was to start going out would that trip the battery icon on the dash?
  4. Jul 21, 2015 at 12:44 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    No.
  5. Jul 21, 2015 at 12:46 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    You shouldn't be having alternator issues unless it was waterlogged or somehow damaged.
  6. Jul 21, 2015 at 1:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    stock batteries in our trucks you can top off with distilled water. This will save a battery from prematurely failing.
  7. Jul 21, 2015 at 1:22 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My stock battery from my 2011 only lasted 3 years. Good thing I was still under my 3yr/36K warranty when it went out.
  8. Jul 21, 2015 at 1:54 PM
    Aw9d
    Aw9d That one guy
    Optima went down hill so much I wouldn't suggest their batteries.
    Here in Az, 2-4 summers and your battery is toast. If you park outside all the time it goes a lot faster. Sealed batteries can last a year or 2 longer if you are lucky.
  9. Jul 21, 2015 at 1:58 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I recommend the interstate battery as well.
  10. Jul 21, 2015 at 2:03 PM
    Aw9d
    Aw9d That one guy
    Interstate Deep cycle has done me right for many years.
  11. Jul 21, 2015 at 2:04 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I replaced a shitty AAA battery in my car with a Mega Tron 2 Interstate battery and it's great.
  12. Jul 21, 2015 at 2:11 PM
    azchris
    Prescott, AZ
    That's literally the point of the battery light...
  13. Jul 21, 2015 at 2:13 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I've had 2 different alternators fail and not once until the battery itself was dead did the light come on..
  14. Jul 21, 2015 at 2:14 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    Yes. Happened to me last night. Voltage gauge showed a spike in power and my battery light came on. Then the alternator died.
  15. Jul 21, 2015 at 2:16 PM
    #35
    azchris
    Prescott, AZ
    Things can fail in various ways. It's not a GUARANTEE that the light will come on any more than it's guaranteed that the oil pressure light will come on before a gaping hole in your oil pan causes your motor to seize, but the entire point of the light is to monitor the voltage and current of the charging system and light up when it goes out of spec.
  16. Jul 21, 2015 at 2:18 PM
    #36
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    exactly it is not directly a warning for the alternator as it is for the battery, if you have a bad alternator and it kills the battery then the light comes on and you swap batteries... the light is not on until the battery drains again.
    Its just there for you to know the battery is too weak and should be checked.
  17. Jul 21, 2015 at 2:19 PM
    #37
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    A lot of places sell remaned alternators and can bench test them.. the pain is you have to pull it out each time.
  18. Jul 21, 2015 at 2:25 PM
    #38
    azchris
    Prescott, AZ
    Oh, is that why the light is connected to the alternator's voltage regulator?
  19. Jul 21, 2015 at 2:26 PM
    #39
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Must be.. wacky science stuff there...
  20. Jul 21, 2015 at 2:27 PM
    #40
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I am talking from my own personal experience with different vehicles.
    The light only came on when the battery was toast.
