PSA: Spare Tire w/wheel locks
Discussion in '4th Gen. Tacomas (2024+)' started by Taco2GR86, Sep 11, 2025 at 4:42 PM.
  1. Sep 11, 2025 at 4:42 PM
    Taco2GR86
    Taco2GR86 [OP] Well-Known Member
    2021 TRD Pro 6MT [sold]; 2024 TRD OR 6MT
    If you have OEM wheel locks, the spare tire crank requires a tool that should be in your glovebox (see photo). The owner’s manual doesn’t mention it.
  2. Sep 11, 2025 at 4:48 PM
    NukenJED
    NukenJED 25 Pro
    Richland, WA
    2025 TRD Pro
    Thanks for the info. But I don’t quite follow. How does the spare have anything to do with the wheel locks on the 4 wheels?
  3. Sep 11, 2025 at 5:33 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Usually if the dealer installs wheel locks they also install a spare tire lock, personally I would have the dealership remove it before taking ownership. I've only had 2 flats to charge during the day but damn I would not want to fight with a spare tire lock when its dark or raining.
    Vitamins, gmtech and FunknNasty like this.
  4. Sep 11, 2025 at 5:34 PM
    BaltimoreMD
    BaltimoreMD Well-Known Member
    4gen Taco Ltd HV
    They are different keys.
    There are the lug wheel locks, then there is the spare tire lock.
    If you have the spare tire lock, the key is different so that it can link onto the lowering crank arm.
  5. Sep 11, 2025 at 6:05 PM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Tacoma Pro and 2025 Tacoma OR Max
    Yeah, I would loose the spare lock before leaving the dealership….knock that key off the crank and it lands inside the spare you are funked. And it’s not if you loose the key it is when you loose the key you will be severely inconvenienced if you need to get to the spare.
    Taco2GR86[OP] likes this.
  6. Sep 11, 2025 at 7:43 PM
    NukenJED
    NukenJED 25 Pro
    Richland, WA
    2025 TRD Pro
    Great advice folks, thanks. But the spare tire lock is an optional accessory. I had to buy mine along with the wheel locks. I think it was $100 or so. I haven’t looked for the key and don’t even know how to lower the spare tbh. Time to learn.
  7. Sep 11, 2025 at 7:56 PM
    FunknNasty
    San Jose
    If get around to lowering the tire, the lock should slip off with a little pull and twist using plyers.
  8. Sep 11, 2025 at 8:06 PM
    NukenJED
    NukenJED 25 Pro
    Richland, WA
    2025 TRD Pro
    I found the locks together in the glove box and looked up the procedure. Looks pretty straightforward. Just slip the spare lock key on the end of the jack extension. As long as the two key locks are together in my glove box, I am set!
