PSI check day...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmb72, Apr 15, 2012.
  1. Apr 15, 2012 at 9:19 AM
    dmb72
    dmb72 [OP] post count low - toyota truck count #6
    Dave
    Oxnard Shores, CA
    TRD 4x4 De Badged
    Tires, De-Badged, Dyno Lock, Tonno Pro Tri-Fold
    I've always been a bit lazy in this area but with my 12 taco & my gg at2's I'm committed to not being lazy. I've been checking the pressure every 2 weeks. Just wondering how often the rest of you check it??? I've been running 34/32 front/rear & they kill the chalk test perfectly at that psi.
  2. Apr 15, 2012 at 9:27 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    My PSI's luckily stay all the same for the most part. I check mine maybe once a month and they are always good to go. I also run 34/32.;)
  3. Apr 15, 2012 at 9:31 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    x2. i think all 4 are at 34 tho or 32. i try and keep all the same. does it ride better 34/32 VS all the same?
    edit: i check mine like once a month. if i am going on a trip that is like 2 or 3 plus hours i will check before i leave.
  4. Apr 15, 2012 at 9:34 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    im at 24 front, 20 rear and still ballooned a little in the middle :p
  5. Apr 15, 2012 at 9:39 AM
    dmb72
    Dave
    Oxnard Shores, CA
    TRD 4x4 De Badged
    Thanks. I'll back it down to monthly & PRE Mammoth 6 hour drives (which I was already doing along with checking all fluids before that drive).
  6. Apr 15, 2012 at 9:41 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I've heard from chris4x4 the treads wear better with those settings.
  7. Apr 15, 2012 at 9:42 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    yeah i check everything before a long trip. like 12h drive to western new york.
  8. Apr 15, 2012 at 9:43 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    just realized my tires are extremely worn for how many miles they have, and its because of how low they are. awesome. will post results after a quick check/inflation.
  9. Apr 15, 2012 at 9:49 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok. than i may switch to 34/32.
  10. Apr 15, 2012 at 10:06 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    wow. 15-17 all around. 33 all around now.
    the 66' vw my sister drives should be at 18/25, was at like 12 and 15. ouch. thats fixed too. i knew today could be productive!
  11. Apr 15, 2012 at 10:09 AM
    dmb72
    Dave
    Oxnard Shores, CA
    TRD 4x4 De Badged
    Glad I could help. :D:D:D
  12. Apr 15, 2012 at 10:15 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    me and BFA was just noticing last night how bad it was. bought the tires in july and hadnt rotated them or checked them or anything. ill have the tire place rotate them just because im lazy.
  13. Apr 15, 2012 at 10:22 AM
    tackytaco
    tackytaco Active Member
    N-Ville
    2012 DC TRD Off-Road 4x4 Debadged
    My original tires came filed with Nitrogen, so when I replaced my wheels/tires I had them filled with N as well and it handles the hot->cold->hot much better than air. Been @ 34 since I put them on 2 months ago and I've made several long trips to all over the southeastern US in the last few weeks. I check mine every 2 weeks just to see ....
  14. Apr 15, 2012 at 10:31 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I usually wait till the TPMS sets an alarm to turn on the indicator.
  15. Apr 15, 2012 at 10:47 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^That's a lot of miles at the wrong PSI, though.
    35 front, 32 rear. Nails the chalk test perfectly. I will say, however, that with the current tires, they take a higher pressure than the Destination AT's I had before. Stiffer sidewall?
  16. Apr 15, 2012 at 12:13 PM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    i'm reading everyone has similar air pressure which is strange to me considering how many different tires brands and load ranges people are running. not saying anyone is wrong but can someone explain this?
  17. Apr 15, 2012 at 2:13 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    It's not just about the tires. Weight has a lot to do with it.
