PSI display does not appear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by XFed, May 22, 2024.
  1. May 22, 2024 at 8:08 AM
    XFed
    XFed [OP] Active Member
    When I choose the car icon on the MID, I cannot scroll down to get to the PSI display. I have tried resetting the TPMS several times as per the manual. Any help would be greatly appreciated.
    Thanks, Wally
  2. May 22, 2024 at 8:20 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    Are you getting the display, just no actual numbers? Sometimes this can take some driving after the reset to pop back up.
  3. May 22, 2024 at 8:20 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A) What's your trim model?
    B) When you say you can't get to the PSI display, do you mean that the display is showing " --" , or do you mean that menu options have completely disappeared? Because one of those is an easy fix.
  4. May 22, 2024 at 9:29 AM
    mitt22
    mitt22 Well-Known Member
    on mine you have to scroll sideways once and then down to get psi
  5. May 22, 2024 at 4:15 PM
    XFed
    I’m not able to get to the display ie; the truck icon with the psi at all the tires.
  6. May 22, 2024 at 4:15 PM
    XFed
    My trim level is sr5. Thanks for any help.
  7. May 22, 2024 at 4:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you have it previously and lose it?
    Any recent tire / wheel work / changes?
  8. May 22, 2024 at 4:32 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If you are getting the. ——- then that’s normal after a TPMS reset. You may have to drive as many as ten miles after the reset before you see the actual tire pressure.
  9. May 22, 2024 at 4:33 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    A picture of what you are seeing would help.
    usmc2msu, Chew and gudujarlson like this.
  10. May 22, 2024 at 4:36 PM
    XFed
    That’s it. I scroll to the car icon and can not scroll down.
  11. May 22, 2024 at 4:45 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    maybe take a video of what you're doing so people can see exactly what your problem is.
    gudujarlson likes this.
  12. May 22, 2024 at 5:13 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not following either.
    I assume:
    - MID is an abbreviation for the head unit (the touch screen display on the dash). I’ve not heard of it referred to as a MID.
    - PSI display is the tire pressure screen in the head unit
    I don’t know what the truck icon is, but I’m guessing you are referring to something on the tire pressure screen.
    When you say, “I scroll to the car icon and can not scroll down.”, I’m wondering why you are trying to scroll down if you are looking at the tire pressure screen
    EDIT: I didn’t mean the touch screen display. I meant the display that has the digital speedometer.
    Phlogiston likes this.
  13. May 22, 2024 at 5:20 PM
    XFed
    Multi Information Display is on the dash by the speedometer. I use the steering wheel button to toggle right to highlight the car icon. From there you are suppose to be able to toggle down and see the psi at each wheel.
  14. May 22, 2024 at 5:21 PM
    XFed
    I had it before but it is gone now. Nothing has changed.
    musicisevil likes this.
  15. May 22, 2024 at 5:22 PM
    gudujarlson
    Minnesota
    Sorry that was brain fart. It’s been a long day. I meant what you are referring to, not the touch screen. In any case, I still don’t understand your issue.
    The tire pressure screen will display —- instead of a number in various cases where the tire pressure is not known. Scrolling down will not change that fact.
  16. May 22, 2024 at 5:44 PM
    XFed
    Thanks for the efforts fellows. I read that the sr5 does not have that feature. I swear I saw it before. Must have been like Bigfoot.
  17. May 22, 2024 at 5:48 PM
    gudujarlson
    Minnesota
    wut? The 3rd gen sr5 certainly has the tire pressure screen. I owned a 2016 SR5. I think it is just the base level SR that doesn’t have it. I have a vague memory of reading that it only has and “idiot light”.
    usmc2msu and Chew like this.
  18. May 22, 2024 at 6:08 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    I have an SR5 and it certainly does have that feature.
    usmc2msu likes this.
  19. May 23, 2024 at 5:53 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I have to say you stumped a number of us with this one. For menu options to disappear either a module went bad or theres a connection deep inside the dash that's loose. That's unfortunately bigger than a simple TPMS issue.
    If I were in your position, I would do the following. Unplug the battery terminal, and then, like an ignorant goon, I would crawl under the dash and wiggle random wire harnesses. Maybe scratch my ass, point a flashlight at it, and see if a neon arrow magically appears and points me at the problem. After 20 minutes I would plug the battery back in and cross my fingers that the hard reset fixes it. If that does nothing, then maybe I would start seeking further advice. (It sounds silly, but sometimes a hard reboot makes it behave.)
    ... If I was really feeling ambitious or desparate, I would pull and ohm-check fuses both inside and out (while the battery is disconnected of course).
    There might be a computer tech on here that's familiar with the electronics. Good luck.
  20. May 23, 2024 at 6:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You didn't happen to accidentally buy a manual transmission Canadian model?
