PSI in KM2 Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tr0gd0r, Jan 2, 2013.
  1. Jan 2, 2013 at 9:02 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    I just got 265-75-16 BFG Mud Terrain KM2 tires installed on my truck. What PSI should I run in them? The shop set them to 35 PSI each, but I want to know what other people in these forums are running on the same tires.
  2. Jan 2, 2013 at 9:05 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    take a paint marker and draw a straight line from one side to the other, go for a drive,
    deflate until the line wears even
    ONLY WAY TO SET THE TIRES PROPERLY
    reason.... your suspension sag, your weight, what you carry in the truck etc...... changes how much they change
    Now if you cant get an even line when filling and deflating there is a good chance you have too much camber/toe
  3. Jan 2, 2013 at 9:09 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Bingo!
    Some also use the "chalk test" - both yield the same result.
    Fink
