PSI in stock tires P245/75 R16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLAJIM, Jun 3, 2013.
  1. Jun 3, 2013 at 5:50 PM
    FLAJIM
    FLAJIM [OP] Well-Known Member
    Jim
    Daytona Beach, Fl.
    2012 PreRunner SR5 2WD
    ARE tonneau cover, Electric Pop & Lock tail gate, 2 lighter plugs in bed, Reese hitch/ factory wiring, OEM Bed Extender and fog lights.
    I am looking for the SAFE max PSI in stock tires for better MPG. The tires are P245/75 R16 on the tires it says, Never exceed 40 psi, door sticker says 30.
    I have read on line some are running 38 in all 4. I am looking for the SAFE number, I do not go off road or carry any loads.
    Thanks in advance JIM
  2. Jun 3, 2013 at 5:54 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Always go by door IMO
  3. Jun 3, 2013 at 5:55 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    i dont have stock tires, but i have 245 E rated and i run 45+- front and rear never have an issue.
  4. Jun 3, 2013 at 5:56 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    why?
    always go by the max PSI on the tire, tire manufacturer knows better than vehicle manufacturer. just my opinion.
  5. Jun 3, 2013 at 6:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    32 psi here.
  6. Jun 3, 2013 at 6:27 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Use the door pressure as a start point and do the chalk test. Then add pressure as required untill you get an even wear off on the chalk you rubbed onto the tire. That way you will know that your contact patch is even and so will the tire wear. Even contact patch is the best for handling and braking too. Use the max pressure on the tire sidewall as your upper limit. Lots of pressure will cause your tire to round out so that only the centre of the normal contact patch is touching which will improve your fuel mileage but its not as safe for braking and will wear the center of the tread more.
    Just use your judgement and some common sense.
  7. Jun 3, 2013 at 6:31 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Not always the correct approach. The numbers on the door are for stock set up with an unloaded vehicle.
    You better call your tire manufacturer for some clarification, you're way off.
    Best and correct response.
  8. Jun 3, 2013 at 6:50 PM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    I run 35 psi in my stock dunlops.
  9. Jun 3, 2013 at 8:08 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    umm, incorrect. the companies work in tandem when specifying OEM, and
    the engineers both at the tire company and at the auto manufacturer
    know a lot about tires, specific automobiles, computerized safety systems, and drivetrain.
    door sticker pressure is the most correct standard to follow when
    the vehicle is shod with oem meats. are variations in this pressure still
    completely safe ? yes, within reasonable limits, and with regard to load and terrain
  10. Jun 3, 2013 at 10:32 PM
    Gus 524
    Justin
    MN
    ^^ this guy! ;)
    I thought he was running stock tires that's why I said run door pressure. I very much agree with the other guys on here don't put them at the max pressure that the tire says unless you do what this guy ^^ said and it works out.
  11. Jun 3, 2013 at 10:41 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    I start at the door pressure and then noticed that the truck would "wander" with a little shudder on the freeway. So, I adjusted the pressure up and down until it all settled down. The truck likes 33psi front and rear so that's what I run and have re-set the TPMS for that pressure.
    Ray
    a400ryan likes this.
  12. Jun 10, 2013 at 6:58 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    I agree with Ray. Replaced dunlops with Mich LTX MS2 (P245/75/16). Truck seems to like 33 psi, door sticker is 30.
    Seems like buried away in the owner manual said add 3# to door sticker for "sustained high speed driving".
