psi over tpms?
Discussion in 'Wheels & Tires' started by justin14200, Jul 22, 2010.
  1. Jul 22, 2010 at 8:51 AM
    justin14200
    justin14200 [OP] frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    i have the tpms sensors mounted in my new wheels, they are duratracs. its max psi is 80 so ill robobly keep it at 60 or 65 psi, will it hurt my tpms sensors? will my tpms light come on or flash at that high a psi?
  2. Jul 22, 2010 at 9:23 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Are the tires stock size? stock pressure is on your driver's door jamb. Unless you're running low profile tires, high pressures are worthless. You will wear out the center of the tread. Put a chalk line across the tire, drive a short distance (in a straight line), check the line. Gone in center, over pressure. Gone on edges, underpressure. Gone, just right.
    Toyotas are shipped from the Mfg with 60psi. It shuts off the TPMS and keeps from getting flat spots on tires.
    Over stock pressure won't hurt tpms, but it will affect handling, and tire life.
  3. Jul 22, 2010 at 9:36 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    my tires are at 35psi
  4. Jul 22, 2010 at 9:45 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    They are probably load range E so the pressure listed in the door jamb doesn't apply.I would start at 65 and go from there.Somebody else running 10 ply tires on a light truck might chime in.
  5. Jul 22, 2010 at 9:57 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    65 - Are you doing that so that all the extra food stuff falls out between your teeth as you drive? I'd switch to flossing - It allows for a much more comfortable ride. :D
  6. Jul 22, 2010 at 4:08 PM
    justin14200
    justin
    baton rouge
    stock
    ok, maybe i should have said"tell me like i was a 7 year old"
  7. Jul 22, 2010 at 4:13 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I run 40-45 psi in my tires for everyday, get a couple more miles per gallon from that but the ride gets a little more harsh at that PSI
  8. Jul 22, 2010 at 4:15 PM
    justin14200
    justin
    baton rouge
    stock
    well, i meant that the tires are 10 ply tires, requiring more pressure. if i have 60 psi in my tires will my tpms light flash because it is way more than what the vehicle calls for?
  9. Jul 22, 2010 at 4:18 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    no, it's a low pressure warning
  10. Jul 22, 2010 at 4:19 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    08 4cly
    Dule Magnaflow Exhaust dumped behind axle, K&N Air intake, Aftermarket radio with a kicker L5 sub & a shit amp, 18" rims with tires, RHLM, DT header, color matched bumper, oem foglights, 8k hids in headlights and in fogs
    it shouldnt hurt the tpms and the light may turn on, but you can recalibrate the tpms there is a little button under the steering wheel just gotta hold it and it will recalibrate everything (please correct me if im wrong), but im not sure how long you need to hold it or if there is anything else you need to do
    like hold the button with your big toe while you pat your head and rub your stomach as you start the truck with your mouth, like you gotta do to turn the damn seat belt chime off haha
  11. Jul 22, 2010 at 6:05 PM
    justin14200
    justin
    baton rouge
    stock
    anyone knw hw to calibrate?
  12. Jul 23, 2010 at 4:25 PM
    justin14200
    justin
    baton rouge
    stock
  13. Jul 23, 2010 at 4:43 PM
    CopDoctor
    08 335i
