PSI question
Discussion in 'Wheels & Tires' started by tacosupreme54, Jun 30, 2011.
  1. Jun 30, 2011 at 11:01 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    I have a couple of quick questions. I just got a set of 295/75/16 hankook mt's. Their max psi is 65. Discount tire installed all four of them at about 35 psi, but they look a little low to me. I know keeping them too low will also wear them out quicker. Higher psi will give slightly better gas mileage. But inflating them too high will make them ride pretty rough and make them easier to puncture. So what in your opinion and from experience is the best psi to run for these with a 65 psi max? maybe 50 psi? or around 40 psi?
    Also another quick question: what effect will cutting my exhaust behind the axle have? I have a 14" magnaflow muffler, but my tip is just getting rusty and I'd like the cleaner look without it. Will it make the sound any/much different? Also, will it hurt anything like the spare tire or need another hanger to support it?
    Thanks in advance guys
  2. Jun 30, 2011 at 11:04 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    id fill it to 40-45, remember air heats up as a tire rolls and increases psi, my taco is filled to 35. plus it depends on your avg load range, ex my doally has load range fs filled to 95
  3. Jun 30, 2011 at 11:05 PM
    Ez2typethis
    Ez2typethis Well-Known Member
    California
    2017 Sport
    Suspension -LSK Uniball Uper Control Arms -LSK Uniball Lower Control Arms -Camburg Performance Spindles -ECGS Needle Bearing Installed -Archive Garage Hammer Hangers -Archive Garage 3.6” Shackles -Archive Garage Hanger Cross Tube -Icon 2.5 CDC Extended Travel Coilovers -Icon 14" 700 pound coils -Icon 2.5 CDC RXT Shocks -Icon 2.0 Hydraulic Bump Stops *Bolt On Bump Stop Mount -Wheelers Front Super Bumps Armor -At The Helm Front Bumper -At The Helm Rear Bumper -At The Helm Rear Swing Out -RCI Sliders -RCI Engine Skid Plate -RCI Transfer Case Skid Plate -RCI Transmission Skid Plate -RCI Fuel Tank Skid Plate -Prinsu Designs Top Rack -Prinsu Designs Cab Rack Lights -Black Head Light Mod -OEM TRD Pro Tail Lights -MESO LED Turn Signals -Morimoto HID Headlight Kit -Caliraised LED 40” Slimline -Caliraised LED 20” Slimline -Caliraised LED Amber Pods -Caliraised LED Wide Ditch Lights -Caliraised LED Flush Mount Pods -LED High Beams -LED Dome Lights -LED Back-Up Lights -LED License Plate Lights Miscellaneous -OVtuned2.0 -4.88 gears -ARB twin comp -ARB rear locker -Leer 100XQ Camper Shell -Smitty Built X20 Winch -Warn Fairlead -Warn Sidewinder -Roto Pax 4.5 Gallon Gasoline -Roto Pax 2 Gallon Water -Roto Pax 2 Gallon Gasoline -Weathertech Floor Liners -Double limo tinted -50% tinted windshield -Leather Seats - Installed At Dealer Wheels and Tires -Matte Black Stealth Custom Series Ray 10's (X5) -BFG KO2 285x70r17 // Load Range C (X5)
    You could probably run those tires around 35-40 psi and be good. 65 psi is too high IMO tho.
    Cutting the tail pipe will make it louder slightly and would probably not have any other adverse effects.
  4. Jun 30, 2011 at 11:07 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Chalk line test
  5. Jun 30, 2011 at 11:18 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    alright, i rarely haul anything. every so often i will load up the fourwheeler in the bed or a couple on a trailer, but that's not often. so 40, maybe 45 psi for daily driving with no load? and do you guys think i will need to re-support my exhaust after cutting it? and is a sawzall with a metal blade gonna do alright on cutting that?
  6. Jun 30, 2011 at 11:45 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    x2 chalk line test, as for the exhaust dump, i had no noise difference when chopping my stock one, can't imagine it being much different with yours.
  7. Jun 30, 2011 at 11:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hankook Dynapro MT's have a max inflation of 80 lbs
  8. Jun 30, 2011 at 11:51 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    these 295s have a max of 65
  9. Jun 30, 2011 at 11:52 PM
    OZ-T
    Peter North
    British Columbia
    Odd
  10. Jun 30, 2011 at 11:54 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, most of the typical sizes for that tire have 80 psi max, but idk. what psi do you suggest oz-t?
  11. Jun 30, 2011 at 11:56 PM
    OZ-T
    Peter North
    British Columbia
    Not that I was doubting you , but the Max PSI does drop to 65 at the 295's per Hankook's website
    I did the chalk test on my 265/70/17 MT's and have them at 34
  12. Jun 30, 2011 at 11:58 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    do you run that same pressure on all four? why do some people run a lower pressure on the rear? because there is less weight in an empty truck bed?
  13. Jun 30, 2011 at 11:59 PM
    OZ-T
    Peter North
    British Columbia
    I have a commercial cap on my truck and I carry tools a lot .
    If the bed was empty all the time I would probably run the rear a couple pounds lower
  14. Jul 1, 2011 at 12:03 AM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    excellent. thanks guys.
  15. Jul 1, 2011 at 2:45 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    The MFG suggested inflation on my 2011 TRD Sport is 29 lbs. front and rear for stock size tires. That seems awfully low. What would you all suggest for stock size tires?
  16. Jul 1, 2011 at 8:24 AM
    Pakow
    Pakow Well-Known Member
    Bay Area, CA
    Tacoma TRD Sport 4x4
    I cut mine with a hacksaw in about two minutes, a sawzall should do the trick in a matter of seconds.
    No additional support added for the exhaust and it does just fine.
    Oh, and chalk test for the tires.
