PSI thoughts
Discussion in 'Wheels & Tires' started by T-Rex266, Oct 11, 2011.
  1. Oct 11, 2011 at 7:04 AM
    T-Rex266
    T-Rex266 [OP] SpaceX Director Moderator
    Elon
    I'm running 285/75/16 Duratracs on a 3" lift. Currently my psi is set @38 all around.
    Thoughts?
  2. Oct 11, 2011 at 7:17 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    what load range? and is your truck 4x4 just asking due to the little bit of extra weight.
    if they are e load range like i think they are your going to want to lower that down to around 32 psi.
    for example my 4x4 regular cab has 295 trail grapplers and i run them at 32 psi they are an e load tire so they are quite stiff as it is.
  3. Oct 11, 2011 at 7:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Seems awfully high. Do the Chalk test to see the best PSI to run.
  4. Oct 11, 2011 at 7:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Chaulk test :cool:
  5. Oct 11, 2011 at 7:21 AM
    Pugga
    Massachusetts
    Dammit! Beat me to it... :eek:
  6. Oct 11, 2011 at 7:31 AM
    T-Rex266
    Elon
    I'll double check the load range.
    DCSB
    TRD Off-Road 4x4 as shown on my page
  7. Oct 11, 2011 at 7:32 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i would do like 34psi, but chalk test if you want it to be perfect
  8. Oct 11, 2011 at 7:32 AM
    T-Rex266
    Elon
    What is this chalk test u speak of
  9. Oct 11, 2011 at 7:33 AM
    Pugga
    Massachusetts
    Draw a line of chaulk across the tread and drive for a very short distance. Ideally, the chaulk should wear off evenly across the tread. If the pressure is too high, the center of the line will wear off and the sides won't, if it's too low, the sides will wear off and the center won't.
  10. Oct 11, 2011 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How to figure the correct tire pressure for larger tires.
    [​IMG]This article was spawned from a continuing conversation from our Jeeping friend Bob in his quest to get his JK handling correctly. If your Jeep is in stock form with stock size and type tires you may not need bother with this article. The recommended pressures listed in the door jamb will suit you fine. But, if you are like most of us your Jeep is lifted and equipped with larger and probably wider tires.
    Typically larger tires handle your vehicles weight differently than stock and the original door recommendations don’t necessarily apply. Why should you care? A tire not properly inflated will wear incorrectly and quicker than a properly inflated one would. Replacing tires that are worn out too quickly will hurt you in the pocket book, in actually more ways than one.
    An under-inflated tire will cause increased rolling resistance which will rob you of fuel economy and possibly damage the tire due to excessive heat. Other symptoms of under-inflation can be a steering pull.
    On the other hand an over-inflated tire can give you an improvement in fuel economy but that savings will disappear when you need to replace your tires sooner. Over-inflation will also cause a harsher ride potential poor handling since the tires may skid over the road instead of grip.
    The right illustration is a cross section giving a better view to what proper or improper inflation does.
    Under-inflated: Wears the edges of the tread more than the center.
    Over-inflated: Wears the center of the tread more than the edges.
    Proper: The entire tread is worn at the same rate (aka, correct pressure).
    What to do?
    Checking proper tire inflation is rather simple and requires some chalk or a utility crayon.
    Make a mark all the way across each tire.
    Drive the Jeep for a short distance, a straight line is best.
    Note the wear pattern in the chalk. If there is chalk left at the edge the tire is over inflated. Chalk left in the center means it’s under-inflated. A clean pattern indicates the pressure is just right. Make a note of the pressure for future reference. This procedure would need to be performed again of different size or style tires are added.
    Chalk Line
    Over Inflated
    Proper Inflation
  11. Oct 11, 2011 at 7:56 AM
    T-Rex266
    Elon
    Load range E
  12. Oct 11, 2011 at 7:58 AM
    T-Rex266
    Elon
    So just drive a short distance with chalk on the tread where it should all fade away away?
  13. Oct 15, 2011 at 8:46 AM
    T-Rex266
    Elon
    How much chalk to apply? I tried this the other day on all 4 and the chalk rubbed off across all 4 rather quickly.
