PSI with aftermarket AT tires (265/70/17)???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DougSD, Aug 4, 2017.
  1. Aug 4, 2017 at 8:06 AM
    DougSD
    DougSD [OP] Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    Discount tire says to run 29psi in the General AT2 tires I got(they are going by the door sticker)
    I've always ran around 31-32psi in all my AT tires ? The values on the door are for the 265/65/17 stock tires but im guessing 29 is a bit too low?
    I can do the chalk method, but usually go by feel as well. I also very rarely carry anything in the bed except surfboards or bicycles.
    I'm probably opening up a Pandoras box asking what folks are running but....
  2. Aug 4, 2017 at 8:12 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  3. Aug 4, 2017 at 8:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are they E load or SL? I'd do 32 front and 30 rear if SL
  4. Aug 4, 2017 at 8:28 AM
    yonah
    yonah Well-Known Member
    Calling-in from east of the Rockies
    Second on the chalk test.
    So many different variables are at play when it comes to proper PSI: vehicle weight, weight distribution, altitude, weather temp, tire load rating, etc. It's one of those things you have to experiment with.
  5. Aug 4, 2017 at 8:28 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Do the General tires have a recommended pressure on the sidewall?
