Psi?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdnbanker, Dec 18, 2008.
  1. Dec 18, 2008 at 2:37 PM
    cdnbanker
    cdnbanker [OP] Well-Known Member
    hey guys,
    i am going to throw 2-300 pounds of sand over the axle
    what should i reduce the PSI on the tires too? 30?
    DC/LB truck
    (this for snow/ice reasons)
    thanks
  2. Dec 18, 2008 at 2:39 PM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'd air up the tires after you throw the sand in there. I had my first experience driving on ice this week, so I'm not too sure about the actual ideal PSI.
  3. Dec 18, 2008 at 3:25 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    I've been wondering the same thing. The door says 33 rear, so I'm thinking 30ish would probably do for winter.
  4. Dec 18, 2008 at 3:28 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    air up man
  5. Dec 18, 2008 at 3:29 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    You could try it out at 30 and see how it goes.
  6. Dec 18, 2008 at 3:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Wow...my door jam says all tires to be at 29psi. I actually run mine at 32-34psi. I might go down to 29 or less this winter (without weight in the bed).
    (2007 TRD Sport)
  7. Dec 18, 2008 at 4:15 PM
    Okkine
    Vancouver, BC
    That's what I had read on here before I bought the truck, so I was kinda surprised when I looked and it said 30 front, 33 rear. It's a Canadian base-model 4 banger, so it might be different from the V6...
  8. Dec 18, 2008 at 4:36 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Here's a article from Tire Rack.
    Winter Air Pressure...You Can't Just Set It...And Then Forget It
    Tires don't really carry the weight of your vehicle...the air pressure inside them does. And maintaining the correct air pressure is a requirement for good handling, traction and durability. The tire pressure recommended in your vehicle's owner's manual or on the tire information placard is a "cold" pressure, so it should be checked in the morning before you drive more than a few miles.
    The fall and early winter months are the most critical times to check your tire's inflation pressures because air is a gas which contracts as the days get shorter and the temperatures get colder.
    For every 10 degree Fahrenheit change in outside temperature, your tire's inflation pressure will change by about 1 psi (up with higher and down with lower temperatures)
    In most parts of the country the typical difference between average summer and winter temperatures is about -50 degree F. That difference results in a loss of about 5 psi, which will sacrifice tire performance and treadwear!
    If you are fortunate enough to park in an attached or heated garage you will also "lose" pressure when you leave its warmth and venture into the real world outside. So add 1 psi of "cold" tire pressure to compensate for each 10 degree temperature difference.
    And finally, don't forget to keep your valve caps on. If left off, moisture can freeze in the valve and allow the air to escape.
  9. Dec 18, 2008 at 6:22 PM
    sonjay
    sonjay Well-Known Member
    Check what the recommended PSI is on the tires. The door pressure is for stock tires. Generally if your carrying any weight you want your tires to be harder. If you don't have enough air in your tires, you risk heating them to much and failure. Especially if you do much high speed (highway) driving. My tires are at 34 psi. If I were going to pack a load I would air them to 40psi.
  10. Dec 19, 2008 at 1:46 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Mine says all 4 at 29 psi also, there are a number of posts where people say their tag says 29 front and 32 rear...is it the 4x4's that are all the same, or which trucks are the same PSI on all 4 and which are different front/rear? :confused:
  11. Dec 19, 2008 at 4:48 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    2007 DC 4x4 Off-Road Short Bed
    Sticker 29 Front, 32 Rear
    My Preference 35
    I air down to 25 in snow storms
