PSI ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by milo, Dec 16, 2013.
  1. Dec 16, 2013 at 10:08 PM
    milo
    milo [OP] Active Member
    George
    Ala.
    stock
    none
    What psi do you run in your tires, I put 35 psi in my 265-70-16, looked on the side of my tires, "damn" it said 50 psi, this would be like ridding a pogo stick, question is what does everybody else run ? First I'm not as smart as the tire engineers , but I know what my ass is telling me . Thanks guys, milo
  2. Dec 16, 2013 at 10:20 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    50 is most likely the max psi for the tire.
  3. Dec 16, 2013 at 10:22 PM
    jaeforceone
    jaeforceone Member
    Jae
    Gainesville, FL
    2013 DCLB 4X4 TRD Sport
    inside your driver's side door panel it should say to keep your psi 29. the 50 psi on the tire is what the max of what your tire can handle before blowing or becoming unsafe. somewhere on here I think someone suggested running 32 front and 30 rear but it may be the other way around. worth a search if your really want to know.
  4. Dec 16, 2013 at 10:44 PM
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I run the same tires on 17's, 32 psi
  5. Dec 16, 2013 at 11:57 PM
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    32 up front & 30 in the rear. World of difference in ride and handling over 29.
  6. Dec 17, 2013 at 12:24 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I run 36 PSI F&R for improved fuel Economy.
  7. Dec 17, 2013 at 12:31 AM
    Slizzy
    Slizzy Well-Known Member
    BC Canada
    '09 MGM TRD Offroad
    Bilstein 5100's @ 1.75" front & 5100 rear, Pro Comp 7089 16x8 4.5"BS, 265/75/16 Duratracs, color matched grille, black emblem
    I run 34 all 4 and I dunno why
  8. Dec 17, 2013 at 2:23 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    look up a tire chalk test - best way to get the longest wear
  9. Dec 17, 2013 at 2:46 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I run whatever that sticker says on all my vehicles
  10. Dec 17, 2013 at 2:48 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Chalk test.
  11. Dec 17, 2013 at 3:02 AM
    milo
    George
    Ala.
    stock
    none
    Thanks Guys, ya'll are the best, gonna back down to 32 psi for the ride, my ass is worth more than long wearing tires. I assume the 32 psi is cold ? milo
  12. Dec 17, 2013 at 3:11 AM
    Joe D
    Joe D .
    I run the suggested from the manufacture of 29 front & 32 rear (for my truck). There is significant scientific testing out there from the government and other sources that show how much or what percentage of power is used to overcome the different forms of resistance in making our trucks (actually vehicles in general) move & I've done some of my own (obviously non-scientific) experiments and haven't noted a significant deference in MPG regardless of how high my PSIG is, just so it's at or above the vehicle manufacture recommendation.
    As far as tire longevity, I've got about 65,000 miles on my original tires. They still have good tread remaining. And I'm satisfied with the ride & handling quality.
    If you're interested there are threads with links attached to non-biased sites comparing MPG etc. in the not too distant past.
    ON EDIT: Yes, set your pressure with cold tires.
  13. Dec 17, 2013 at 4:13 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    As long as you are not hauling anything 35 psi is fine and will give a better ride, but your MPG will suffer. If you haul weight you should increase the PSI closer to the max to keep the sidewalls from breaking down.
  14. Dec 17, 2013 at 5:26 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    How does MPG suffer with 35 PSI? Generally an inflated tire gives a bit less rolling resistance and an increase in MPG.
  15. Dec 17, 2013 at 5:36 AM
    car78412
    Hudson Valley NY
  16. Dec 17, 2013 at 5:48 AM
    Tacologist
    Bob
    Tenessee
    :notsure:
  17. Dec 17, 2013 at 5:49 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    40 PSI front and 38PSI rear, chalk tested. Have very even wear at about 20K miles.
  18. Dec 17, 2013 at 5:54 AM
    rustbus
    rustbus Well-Known Member
    western Canada
    2012 TrailTeam Pro - white
    I inflate per the toyota directions.
    increased (overinflated) tire pressure = increased suspension component wear.
  19. Dec 17, 2013 at 5:58 AM
    Joe D
    Joe D .
    http://www.fueleconomy.gov/feg/atv.shtml
    This link provides data about where the energy goes. Rolling resistance consumes approximately 5% to 6% of all the energy produced (combined). IMO, not exactly a large amount. Even if I could cut that number in half to something like 2.5 to 3%, at ~20mpg it isn't much. I would question even being able to shave that number by a tenth even going from 35psi to 50psi (but I really don't know). At 12,000 miles a year with 20mpg at $3 a gallon it's only around $45 a year. Skip the Starbucks a few times if its an issue and you're there....
  20. Dec 17, 2013 at 6:02 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    32 front, 30 rear.
