Psssst What Mileage You At?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wengel21, Aug 26, 2024.
  1. Aug 26, 2024 at 9:30 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Just went over 30K miles on my 2021 Sport--brought home on May 14, 2021.
  2. Aug 26, 2024 at 9:36 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    85k on my 2020. No issues.
  3. Aug 26, 2024 at 9:55 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    92k on 2016 sr5. Transmission cooling lines leaked. Covered after being firm by Toyota, rest is just normal wear.
  4. Aug 26, 2024 at 9:56 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    9357 on the mall crawler
  5. Aug 26, 2024 at 9:59 AM
    Unit59
    Unit59 Keystone State
    Craig
    East Central PA
    2023 Tacoma TRD OR
    My 23 has 5,517 all is well.
  6. Aug 26, 2024 at 10:00 AM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    4,957. Have owned it for 11 months, less 4 days.
  7. Aug 26, 2024 at 10:02 AM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    28k on my ‘23 purchased on 1/28/23
  8. Aug 26, 2024 at 10:18 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    ~ 50k miles on 2018 OR. Normal wear and tear, no outstanding campaigns or recalls. Happy so far.
  9. Aug 26, 2024 at 10:18 AM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    2017 Trd Sport and i just rolled 205,000 km / 127,000 miles
  10. Aug 26, 2024 at 10:20 AM
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    125k on 17 off road. 3rd brake light leak under warranty. Tie rods at 85k and new power steering pump at 100k. Other than that normal maintenance
  11. Aug 26, 2024 at 10:53 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    56K on a 2021. Had to replace the driveshaft center support bearing, leaky PS reservoir, and now the rack boots are sweating a bit. I'm letting that one ride as long as I can.
  12. Aug 26, 2024 at 11:04 AM
    josefmd
    josefmd Well-Known Member
    Springboro OH
    2017 4R TRD Pro Cement. 2024 Ford Ranger Raptor
    12k and some change on my 23 bought in April of 23. No issues after the initial left over loose bolt removal inside dash
  13. Aug 26, 2024 at 11:26 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Will roll over to 250,000 in a couple of days. Other than normal parts replacement and maintenance the only thing I've replaced was the alternator and a U-Joint at around 170,000. Toyota did replace my rear springs at 200,000 as part of a recall.
    mattm55 likes this.
  14. Aug 26, 2024 at 11:38 AM
    RetNavTaco
    RetNavTaco Member
    2017 Offrd
    2017, 102K not a single issue
  15. Aug 26, 2024 at 12:24 PM
    #35
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    217,000 miles on my 2016.
    Problems are starting to accumulate but I drive hard and wheel it. Good about basic maintenance.
    Mods:
    - Full RCI skids aluminum + rear bumper + sliders
    - front warn hybrid bumper and warn 8k winch
    Bilstein 8112, 8100 + ICON leaf pack, 2 inch lift
    Arb air lockers
    Maintenance:
    Oil change + air filter every 5-6k
    Spark plugs every 60k
    Diffs+ transfer case service every 30k miles
    Coolant serviced every 50k miles
    PS fluid changed once
    Brakes bleed once
    Third set of front rotors
    Only touched the drums once
    Replaced items or items wearing out:
    Serpentine belt replaced at 150,000
    - 2 wheel bearing replaced, 1 front 1 rear
    - rear u joints and carrier bearing replaced at 200,000
    LCA’s replaced with OEM at 185,000
    Aftermarket bilstein UCA’s
    Third set of shocks, Bilstein 8112 front 8100 rears, 2 inch lift
    RCI leaf pack
    New Tie rod ends
    CV’s have been re booted
    Steering rack has small seep and the bushings are going out
    Needs new body mounts and radiator mounts
    CPS replaced under warranty
    Radiator support sheet metal is starting to crack
    AF sensor went out
    One Cat has been replaced
    Exhaust has gotten louder and now drones at highway speed.
    Awesome truck, very capable and reliable overall. Just put 6,500 miles on it driving from Colorado to Canada and back. Hoping to make it to 400k before I get a 4th gen.
  16. Aug 26, 2024 at 12:32 PM
    #36
    bigredhusker
    bigredhusker New Member
    Russ
    2017 TRD OffRoad
    2017 TRD Off Road 69K
    Trouble free
  17. Aug 26, 2024 at 12:40 PM
    #37
    TacoBerto
    TacoBerto Member
    Pittsburgh, PA
    2020 OR DCSB MT
    2020 TRD Off Road DCSB MT, 28k miles. No issues so far. WFH 3 days a week so I don't put a lot of miles on it.
  18. Aug 26, 2024 at 1:00 PM
    #38
    sbl23
    sbl23 Well-Known Member
    Bryant
    Minnesota
    2020 DCLB TRD OR Black
    2020 TRD OR - 125,544mi
    I try to stay on top of maintenance but there are some places that I have been lacking. I would say that I am similar to @DRAWN 's experience with this truck.
    Mods:
    - Backwoods Adventure Mods aluminum bumper and Warn 10K winch
    - JBA UCA
    - RCI Steel Skids Full Package
    - Steel Sliders
    - Eibach Stage 2 Suspension
    Maintenance:
    - Oil and Filters - Mobil 1 0W-20 every 6K miles
    - Transfer Case and Diff Oil - Mobil 1 75w90 - Every 60K
    - Spark Plugs - OEM every 60K
    - Lower Radiator Bushings - Energy Suspension at 80K <--- Don't fucking do it. Stick with OEM bushings.
    - Serpentine Belt - OEM at 84K
    - Transmission Fluid Service at 86K
    - Brake Job (Front) - OEM at 102K
    - Refreshed Front End - OEM at 113K
    ---- OEM LCAs and Hardware
    ---- OEM Inner & Outer Tie Rods
    ---- OEM Steering Rack
    - Replaced Radiator Core Support Sheet Metal and Lower Radiator Bushing - OEM at 113K <--- Fuck Energy Suspension Lower Radiator Bushings
    - Fan Clutch Replaced - Aftermarket at 123K
  19. Aug 26, 2024 at 1:19 PM
    #39
    rambandit73
    rambandit73 Well-Known Member
    2023 TRD Sport Premium 6MT
    14,950 on my ‘23 6MT. Only issue I’ve had is a squeaky clutch pedal which I resolved with a touch of brake caliper grease applied on the pedal shaft. Otherwise, purrs like a kitten!
  20. Aug 26, 2024 at 1:39 PM
    #40
    shellshock08
    shellshock08 New Member
    2023 Tacoma TRD pro
    9,762 on my 2023 pro AT. Just got my last freebie oil change this past Friday.
