PT948-35160 Bed Lighting Kit Install Instruction (2017 Model Year)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Aug 24, 2019.
  1. Aug 24, 2019 at 10:39 PM
    KY_Rob
    KY_Rob [OP] Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I’ve been able to find install instructions for 2015 and older OEM bed lights here on TW, as well as elsewhere on the interwebs. However, the kit I recently bought did not include instructions (or mounting templates), and had a note stating I needed to get them printed from a dealer.
    Seems like the kit has been updated a bit. There’s now grommets included behind each light and OEM style connectors already in place where they need to be. Yes, I can certainly figure it out, and successfully install them without the instructions. However, it would be nice to see what’s actually changed from an install perspective.
    Thanks!
    r_to_the_k likes this.
  2. Aug 24, 2019 at 11:55 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Subd. I’m thinking about installing these too.
  3. Aug 25, 2019 at 8:32 AM
    KY_Rob
    Rob
    North East Ohio
    Kudo’s to McGeorge Toyota Online. Send them an email late last night (on a Saturday), after making this original post. 20 mins ago, I get a link to the 2016+ install sheets for Double & Access cabs! File is attached for all’s enjoyment.
    From 2015 and below to 2016 and above, I noticed the following changes:
    - Mounting hole sizes increased from 7/64 to 1/8 for 2016+
    - 1-1/8” hole saw required for the wire lights and grommets in the 2016+
    - Detailed locations of wire tires for the 2016+
    - IE1 pin-out details for both cab configurations for 2016+
    DAS Taco, Houstonian and davidstacoma like this.
  4. Sep 2, 2019 at 10:16 PM
    KY_Rob
    Rob
    North East Ohio
    Follow Up - Post Install:
    I’ll post pics later, as I didn’t have time to take them.
    This 2017 model bed lights kit has been vastly improved, when compared to the kits used in videos available on YouTube. A pre-wired in-line fuse is supplied in the feeder cable, and cable lengths are almost perfect. I had about a foot of extra cable, that was really easy to deal with and didn’t require cutting out excess and splicing.
    Grommets are supplied behind each light (1-1/8” hole required) as well as for the body access near the drivers seat, and they do not need to be removed during installation.
    The first thing I noticed, was that the instructions explicitly call out an access hole that’s not mentioned in any of the videos I could find. Using the specified hole, made it possible to not have to remove the seatbelt trim behind the drivers seat. The provided instructions also call for different installation procedures, which made running the primary supply cable a little easier (getting over the fuel tank still sucks bad). You basically start at the specified hole, feed your termination end up under the carpet, and seat the grommet that’s on the cable.
    Going through the cab routing and termination sequence is fairly easy. Yes, against my better judgement I used the supplied vampire clip for +12v, just because of where the connection is and access to clip in the future. I gobbed some e-grade silicone in the vampire clip for my own piece of mind. For the ground, I did install a fork terminator, and installed that under the bolt for the near by ground cluster.
    Routing the cable from under the truck is easy...except for going over the fuel tank. Spent almost 90 mins on that part alone.
    The light install is clean, and very functional. Works in conjunction with the high-mount cab light, including the off/door/on switch on the dash.
    AKGSD likes this.
  5. Sep 2, 2019 at 10:42 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Night pics would be awesome, this kit has been on my want list....
    KY_Rob[OP] likes this.
  6. Sep 3, 2019 at 5:11 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Night pic on my IG. www.instagram.com/cementgray
    I don't have access to it from here.
  7. Sep 3, 2019 at 7:57 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I installed this same kit on my truck. Easy install, you are right about fishing the wiring harness over the fuel tank. That took me hours to get it just the way I wanted it.
  8. Sep 3, 2019 at 12:08 PM
    Panchovilla6192002
    Arizona
  9. Sep 3, 2019 at 12:33 PM
    bonifacio
    Central PA
    Pablo8 and KY_Rob[OP] like this.
  10. Sep 4, 2019 at 10:22 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Anyone know if this kit works for 2nd gens? Any pics of the lights used? Where is the switch located?
    Thanks!
  11. Sep 4, 2019 at 6:47 PM
    KY_Rob
    Rob
    North East Ohio
    Went out to take a night pic of mine, but it didn’t look as good as @bonifacio ‘s, so I settled for pics of the installed lights themselves.
  12. Sep 4, 2019 at 10:22 PM
    Panchovilla6192002
    Arizona
    Look nice.
  13. Sep 5, 2019 at 9:44 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    where did you all get the kit from? I found it on Amazon for 123ish
  14. Sep 5, 2019 at 6:17 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    I had the salesman order it for me as part of the deal when I bought the truck. Also had him order a bed mat at the same time.
  15. Sep 6, 2019 at 3:22 PM
    bonifacio
    Central PA
    Prices? Just curious what deal pricing is.
  16. Sep 6, 2019 at 3:34 PM
    KY_Rob
    Rob
    North East Ohio
    I paid $115 for these from McGeorge Toyota Online
  17. Sep 6, 2019 at 4:13 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Will check when I get home tomorrow.
  18. Dec 25, 2020 at 3:08 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Got one of these for Christmas!
  19. Aug 26, 2022 at 12:08 PM
    Yota116
    Yota116 Active Member
    JW
    2018 Tacoma Sport
    Realize this is a old thread but wanted to add since I finally decided to add bed lights for my 2018.
    PT948-35160 = has rubber grommets preinstalled on the wire harness for the cab floor and where lights attach onto the bed. Requires drilling a larger 1 1/8" in hole in bed to mount.
    Part #'s: 00016-34187; 00016-35087 These do have grommets on the harness. Drill hole size in bed is much smaller (just enough to pass wire). Where wire passes into to cab floor the instructions say "cut a slit in the existing grommet and seal with silicone" You can see that here for comparison against PDF instructions shared above by OP. http://toyotaparts.sparkstoyota.com/install/00016-35087inst.pdf
    One additional difference: all use a T taps to grab power from driver foot well but the type of T tap style varies (two wire pass through vs single wire w/ spade plug in)
