pta_taco 3rd Gen Build
Discussion in '3rd Gen. Builds (2016-2023)' started by pta_taco, May 29, 2017.
  1. Aug 12, 2018 at 8:30 PM
    #61
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Hey pta_taco. Love the truck, I run the same size of tire 255/85 but in KM2s. Now that you have had them for some time, has your opinion changed. I just barely put my 255's on and now have the bug to get some sweet rims like the ray 10's or sr8s. I feel like the offset that they run would not work with this tire size though. I have run both .75" and 1" bora spacer. The only time I have rubbed the cab mount is with the 1" spacer. I believe the scs wheels would move the tire out 1.5" over stock. Other mods that affect rubbing would include JBA control arms set at 3 degree caster. Thanks
  2. Aug 15, 2018 at 9:39 AM
    #62
    pta_taco
    pta_taco [OP] Exploring when I can
    Patrick
    Greenville, South Carolina
    2016 TRD Off-Road
    https://www.tacomaworld.com/threads/pta_taco-2016-offroad-build.493686/
    Tires are still holding up great. Still in love with the tire size. I know KM2s are slightly bigger then ST MaxxS so your rubbing experience might be different then mine. I only rub at full lock while running at 30psi or lower.
    I can take a picture of how far the tire sticks out of the wheel well to help you get an idea. Because I don’t know how far out the new rims actually push them out over stock. Maybe the spacer pushes out further then a SCS rim but I do not know.
    But as for UCAs I still am running stock (still want to switch but bought a boat... cut back my funding. Haha) but there’s is plenty of room behind the tire for an upgrade.
  3. Nov 10, 2018 at 7:52 PM
    #63
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Hey @pta_taco,
    How do like the molle config on your driver's seat? I've been looking to get something similar.
  4. Nov 11, 2018 at 6:42 AM
    #64
    pta_taco
    Patrick
    2016 TRD Off-Road
    I love it. No problems fits plenty of gear that was just sitting around the truck. Wanting to get a second one for passenger side but just haven’t pulled the trigger yet.
  5. Apr 1, 2020 at 9:51 PM
    #65
    Mallardmaster1
    Mallardmaster1 Member
    Jeremey
    Cape Cod, MA
    2006 Blue Tacoma SR5
    Did your lift settle at all since then? I'm wondering if I can fit the 255/85r16 with a 2" lift in the front and 1.5" in the rear with my second gen. Are you at 1.5" of lift in the rear when you have your tent setup on the bed? And when you take it off you're at 2" of lift in the rear?
  6. Apr 2, 2020 at 6:22 AM
    #66
    pta_taco
    Patrick
    2016 TRD Off-Road
    Without the tent the rear sits about 1.75 higher than stock, with a tent 1.5. Even towing a boat and tent on still would sit an inch higher than stock.
    the front dropped alittle over time. It sits about 2 inches over stock now
  7. Apr 2, 2020 at 7:07 PM
    #67
    Mallardmaster1
    Jeremey
    Cape Cod, MA
    Thanks for the quick response. Love what you've done to the truck, it looks really good. Sub'd. Any rubbing when you're an inch higher than stock when towing with the 255's?
  8. Apr 4, 2020 at 4:21 PM
    #68
    pta_taco
    Patrick
    2016 TRD Off-Road
    Nope I haven’t experienced any rubbing in the past three years now. Towing or off-roading. Haven’t done any trimming
  9. Jul 23, 2020 at 2:15 AM
    #69
    UnconqueredNole25
    UnconqueredNole25 Well-Known Member
    2017 Tacoma SR5 double cab
    Did you have any rubbing with the 265/75R16 KO2s prior to your lift? I just bought a set of Ray 10s 16x8 -12mm offset and i'm trying to decide on tire size. I have a stock suspension 2017 SR5. I appreciate any insight. Love the build you put together!
  10. Jul 23, 2020 at 4:28 AM
    #70
    pta_taco
    Patrick
    2016 TRD Off-Road
    I didn’t have any rubbing issues at all with 265s. I don’t know if the sr5 has the air-dam, but the off-road does not come with it so I dont know if That will be a factor for you.
  11. Jul 23, 2020 at 10:38 PM
    #71
    UnconqueredNole25
    It did have the front air-dam but I took it off and I don't have any mud flaps (seems like those 2 things are what most complain about first with clearance issues). I'm not sure if the off-road comes with a little extra height from factory than the SR5. Thanks for the response!
  12. Jul 8, 2021 at 6:54 PM
    #72
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    i just went up to 255s but havent towed yet. i have a lightweight camper... about 2,000lbs loaded with gear. you think it'll be a dog going up to the mountains? I have a 2nd gen v6 w/ tow package. nice truck man!
  13. Jul 9, 2021 at 3:01 AM
    #73
    pta_taco
    Patrick
    2016 TRD Off-Road
    I use to tow a boat, weighing around 1800, didn’t have much of a problem. Even in the Sierra mountains it was towing fine. Rpms got a little high in some parts but nothing to crazy.
    dirtnsmores[QUOTED] likes this.
  14. Jul 10, 2021 at 1:02 AM
    #74
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    You've got my dream suspension and tire setup! I was worried that the tires might look a little skinny but they dont look half bad in the pics.
    16MPG with 33s and an RTT sounds like highway miles though. I get 16MPG in the city stock just w/ racks and I drive like an old man.
