PTC heater - feel the heat?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Jan 22, 2019.
  1. Jan 22, 2019 at 8:19 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    There is another post here talking about the 3 relays, how they work and at what temperature. I found the 3 relays on my 2018 Tacoma but I'm not sure it does anything noticable. For those in cold climates, are you able to tell any difference at all?
    Anyone know the 3 fuse ratings? The Prius has 30A+30A+50A so I'm guessing this is similar and over 1kw. Surley I should feel a little heat right?
    :::EDIT:::
    Turn the fan on low, temp to "HI" and you should feel some heat a few seconds after starting your truck cold. The PTC only runs when the temp is set to HI.
    SR-71A likes this.
  2. Jan 22, 2019 at 9:34 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Mine works, remember to crack the heat to max to activate it.
    shakerhood likes this.
  3. Jan 22, 2019 at 9:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It seems to help a little.
    tonered likes this.
  4. Jan 22, 2019 at 9:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm assuming this is a 3rd gen thing? That's pretty cool.
  5. Jan 22, 2019 at 10:48 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Are the fuse/relay locations the same on the Tacoma?
  6. Jan 23, 2019 at 12:43 AM
    myamada1230
    myamada1230 Well-Known Member
    Greenacres, WA
    2021 TRD Offroad DCLB
    I have noticed this, but only when the temp is set to high. It takes 90-120 seconds or so, but it definitely blows warm air long before the temp needle even starts to move. It is by no means hot, but is warm enough to start defrosting the windshield/warming up the truck.
    The hammer likes this.
  7. Jan 23, 2019 at 3:08 AM
    soggyBottom
    Does the fan speed matter?
    Does it only work on defrost or any vent?
    02Duck likes this.
  8. Jan 23, 2019 at 6:03 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^TRY THIS^^ +1
  9. Jan 23, 2019 at 8:26 AM
    soggyBottom
    Just tried again this morning. I turned the fan speed down this time and I could feel the heat. Thanks guys
    02Duck, Captqc and tonered like this.
  10. Jan 23, 2019 at 8:31 AM
    Rebelman21
    Rebelman21 Well-Known Member
    Cleveland
    2021 SR5 DCSB Super White
    None yet, several planned
    How come this is not more well known? I have never heard of this after owning 2 3rd gens.
  11. Jan 23, 2019 at 8:40 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Thats kinda neat. Almost 1500W of heat (if its the same as the Prius - which it probably isnt..)
  12. Jan 23, 2019 at 8:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  13. Jan 23, 2019 at 8:49 AM
    SR-71A
    Zack
    Southern Maine
  14. Jan 23, 2019 at 8:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true!
    I'm just stoked that the TSBs released in the last 6mos have really quieted down a lot of the big issues and repeats threads.
    SR-71A[QUOTED] likes this.
  15. Jan 23, 2019 at 10:09 AM
    Rebelman21
    Cleveland
    I know all salesmen aren't created equal, but they should certainly mention this trick. Especially when in a colder climate. Maybe I'm asking too much though.
    cryptolyme and tonered like this.
  16. Jan 3, 2020 at 8:44 PM
    Bob K
    Bob K Well-Known Member
    Bob
    2017 TRD Off Road
    I'd guess because it's not in the owner's manual.
    There are 70 hits for "heater", 72 hits for "max" and 0 hits for "PTC" in the 2017 TRDOR owner's manual. None of them talk about the electric PTC heater. Nor is there anything in Section 6 of the manual that discusses operation of the PTC heater. The only reason I know about it is by word of mouth.
    Seems rather dumb for Toyota to exclude information about a feature that supposedly can only be activated under certain conditions and switch settings. I've always just set my automatic temp control to the temperature I wanted (say, 75 degrees in winter) and let the system do its work as the coolant warmed up. Never knew I needed to set the temp to "MAX" or "HI" in order to get the PTC to turn on.
    Plus, I just tested this in my vehicle. About 29° F outside, cold-soaked motor. Set HVAC to "auto" and temp to "HI". The fan was completely off for about 4 minutes and then turned on to the lowest speed. 20 seconds later it increased speed 1 setting. I felt very warm air. The fan stayed on to the second speed and the heat continued even when I reduced the temp from "HI" to 72 degrees, leading me to believe that the PTC operation is automatic regardless of temp setting, not manual. I don't believe 4 minutes of runtime would heat the block and coolant up enough to circulate 80-100° coolant through the heater core.
    Thoughts?
    cryptolyme likes this.
  17. Jan 4, 2020 at 4:36 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I've never heard of if. Don't know if my SR5 has it. :notsure:
    Will try to remember to check it out.
  18. Jan 4, 2020 at 5:02 AM
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    So is this just on dual zone auto AC?
  19. Jan 4, 2020 at 6:10 AM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    I'll be that guy this time...
    GTFO... these trucks have that?! I'm going to have to sniff around the heater box today. If there's an 8ga or so wire going to it, it would probably be that.
    (I'm familiar with the systems on other vehicles, that's why I'd be surprised to see it in a taco. It's a non-phev, non-flagship vehicle line or model. Not really anyway.)
    Edit: quote from the other thread I just saw:
  20. Jan 4, 2020 at 7:44 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Check the fuse box under the hood. If you have a PTC heater relay installed, then you should have it.
    Based on the service manual, it seems to be on every model.
