Public Service Announcement: Avoid MOOG sway bar end links (2001-2004)
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazytacoman, Oct 11, 2020.
  1. Oct 13, 2020 at 3:02 PM
    new1stgen
    new1stgen Member
    I found that the 11/16 wrench that came with a die grinder was the perfect size to get on and hold the flats behind the control arm mount point. It was a pain to find the right tool to do it, but I really appreciated the wrench flats when I needed to remove the links to do control arm bushings.
    I’ve been running these for several thousand miles and they’re showing no signs of wear so far.
  2. Oct 14, 2020 at 1:43 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Over the years I have modified many tools to make things easier on me.
  3. Oct 14, 2020 at 1:13 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    This. I only buy genuine OEM replacement parts. Too expensive? Well, there are discount dealers out there. My complaint now is Toyota starting discontinuing the Gen1 parts awhile back.
  4. Oct 14, 2020 at 3:39 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    The OEM ones suck in the rust belt. They need to be removed with a cutoff tool.
    goldentaco03 likes this.
  5. May 29, 2021 at 2:06 AM
    Vicious Beaner!
    Vicious Beaner! New Member
    Eric
    02 4x4 DB CAB
    I'm having a hard time removing the lower end link like stated above cuz the curve on the lca. Howd you go about holding the stud while undoing the nut ?
  6. May 29, 2021 at 9:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  7. May 29, 2021 at 12:29 PM
    crazytacoman
    crazytacoman [OP] Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I sprayed it with PB blaster and used a powerdrill with a socket extension. You could try holding the inside/outside part of the bolt with an adjustable wrench while you try loosening the bolt
  8. May 29, 2021 at 6:00 PM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Had the same issues with the Moog end links. Had to take the wheel off to get a wrench jammed in there.
  9. May 29, 2021 at 9:26 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Why anyone would go through the trouble and hassle of swapping this crap out and then installing China crap that’s made out of our rusting bicycles, is beyond me.
    Buy OEM, nothing compares to it. And it is absolutely not incredible more expensive.
    How dare you disrespect your Tacoma with inferior parts.
  10. May 30, 2021 at 5:51 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Save the expense and headaches and remove the sway bar altogether.
    My 3 link SAC doesn't have one and it's a DD.
  11. May 30, 2021 at 8:57 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Yeah, WTF. Who needs that shit. After all, the hundreds of millions of cars and trucks in the world that have them will more than make up for those who think they don't need them.
    Who needs a sway bar... Who needs safety anyway...
  12. May 30, 2021 at 9:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tons of cars were manufactured without sway bars.
    Yes a sway bar adds some stability, but it's felt only at hard turns and at speed.
    Myself, and many others though have removed our sway bar to no ill-effects.
    Just don't drive like a moron, and you're good. You're making it sound like someone ripped out the brakes or something :burp:
    jbrandt and Ritchie like this.
  13. May 30, 2021 at 1:06 PM
    Ritchie
    Yeah, you might need one at a mall while making quick u-turns to pick up chicks...
  14. May 30, 2021 at 2:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You don't; you find the highest curb and drive one wheel up it to flex :muscleflexing:
    Leave it there until your post gets enough followers
    #doitforthegram
    Ritchie and High Noon like this.
  15. May 30, 2021 at 4:09 PM
    #35
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    You know what. I am about to unleash years of pent-up frustration regarding sway-bar deletes. Get prepared for these paragraphs! :ohsnap:
    Kwikvette likes this.
  16. May 30, 2021 at 6:44 PM
    #36
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    It’s never going back on
    Kwikvette[QUOTED] likes this.
  17. May 30, 2021 at 6:46 PM
    #37
    Kwikvette
    Fresno County
    4 run, 2 don't
    @jbrandt
  18. May 30, 2021 at 10:17 PM
    #38
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Sway bars are like vaccines. The more other people have them, the less important it is for you have one.
    tacomataco2 likes this.
  19. May 30, 2021 at 10:54 PM
    #39
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    When taking stuff off, I find the smoke wrench fits every size fastener, and gets those stuck nuts loose with little trouble.! ;-)
    Ritchie likes this.
  20. Jun 1, 2021 at 8:33 AM
    #40
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I can only afford an 1/8th at a time.
