Puddingheads at the tire shop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zooks527, Apr 8, 2017.
  1. Apr 8, 2017 at 6:05 PM
    Zooks527
    Zooks527 [OP] Active Member
    Mansfield, MA
    2005 Tacoma TRD Sport Access Cab
    DDX3 BT radio, tailgate cam, heated seats
    Weather forecast for Tuesday is 78 degree, so I decided I'd pull the snow tires off my truck and car today. Was partway through the car and decided I'd save some time and drop my truck at the local tire shop that's a mile from my house.
    Stupid move.
    Went pear-shaped when I picked it up. First guy at the counter handed me my key and asked for $117. My response of "For putting on an already balanced set of wheels??" was met with "Oh, must have picked the wrong line off the price list." and re-ran it for $22.
    Took the truck out on the highway (right by the shop) and ran it up to 80 to check for vibrations. Nothing. Great. Slid over to the ramp, pressed on the brake, and tried to keep my fillings from rattling out of my head. Wheel was shaking, truck was shaking, I was shaking.
    Clearly, someone had torqued something down to the point of pulling a rotor out of plane. No problem, I've got my wrenches out, I'll crack the nuts and set them correctly.
    Nope. Couldn't break them at all by hand. Damn. OK, pull out the impact wrench.
    Nope. Granted, it's an electric model and only good to 250 lb*ft, but it couldn't move a single lug on the front wheel I tried. Chucklehead must have run the wheels on with an air gun and hammered them all the way home.
    Back to the shop. Leave the truck. Come back 4 hours later. Still not done, but they suggest I drive it for a few days to let everything seat. Uh, no. I'll wait. Let's crack the nuts, shall we?
    Sitting in the shop, I can hear the tech trying to get them off with his impact wrench. 10 - 15 seconds or so of hammering on just about every stud.
    Got it back 20 minutes later, back on the highway, and the brake pulse is gone. I'm going to crack and reset every nut tomorrow anyway, just on general principles. And I know what's not happening in the fall when the snows need to go back on.
  2. Apr 8, 2017 at 6:09 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Cool story
  3. Apr 8, 2017 at 6:16 PM
    Jeffas7
    Jeffas7 Monta what na???
    Missoula
    12quad6spd
    'Murica
  4. Apr 9, 2017 at 4:27 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Sounds like the guys you dealt with were maybe flipping burgers the week before...hard to find good help these days.
  5. Apr 9, 2017 at 5:45 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    You should invest in a torque wrench (click-type)
    Doughnut Spaghetti likes this.
  6. Apr 9, 2017 at 5:55 AM
    Zooks527
    Mansfield, MA
    I have one and was using it when I was changing the tires out on my car. I check and reset the nuts anytime someone other than me changes a tire. That's one of the ways I knew the truck was off.
  7. Apr 9, 2017 at 6:12 AM
    Blockhead
    Pittsburgh, Pa.
    I assume you'll no longer be using their services? Being a mile from your house, are you a regular customer?
  8. Apr 9, 2017 at 6:12 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    And you still couldn't undo them? This shop clearly had no regard for torquing to spec. Good plan on never going there again.
  9. Apr 9, 2017 at 7:29 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Put some anti-seize in those lug nuts while youre at it.
  10. Apr 9, 2017 at 7:48 AM
    Zooks527
    Mansfield, MA
    Yeah, they're off the list. I've only used them for tire services (my go-to mechanic is a 20 minute drive away) since they screwed up an oil change one time ("forgot" to change the filter), but now they're fallen off all the way.
    No big loss, according to my wife.
    Yeah, they just ran them on as hard as they could.
