Puddle Light connection.
Discussion in '4th Gen. Tacomas (2024+)' started by Tidnish, Jun 27, 2024.
  1. Jun 27, 2024 at 3:03 AM
    Tidnish
    Tidnish [OP] Member
    Hello. I have a ‘24 TRD OR Premium and so far, it’s good.
    I want to add puddle lights to the underside of the running boards wired to come on with the bed lights. I believe I saw a post where these could be connected to a BLUE wire from the bed lights but can’t recall where. Can someone help?
  2. Jun 27, 2024 at 4:46 AM
    Toy-Truck
    Toy-Truck Well-Known Member
    Following thread
  3. Jul 2, 2024 at 3:06 AM
    Tidnish
    Tidnish [OP] Member
    Replying to move to the top in hopes someone can advise the best way to connect puddle lights to come on with the bed lights? I’d appreciate any advice. Thanks Folks.
  4. Jul 2, 2024 at 8:00 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I think you could use a relay switch and connect the switching power to that circuit using a tap-it fuse connector. Find the fuse for the bed lights in the box and go from there.
  5. Jul 28, 2024 at 7:54 PM
    caribe makaira
    Caribbean, Puerto Rico
    Bad info Sagebrush.
    OP, identify the wire that supplies fused juice to bed lamps. Use that as a trigger to an added relay for the puddles.
  6. Jul 28, 2024 at 8:57 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    And why is that bad advice?
  7. Aug 1, 2024 at 9:56 PM
    caribe makaira
    4th Gen has no fuse specifically for the bed lights.
  8. Aug 1, 2024 at 11:04 PM
    caribe makaira
    Another option:
    Turn on with unlock/lock.
    Or add an ON-OFF-ON switch:
  9. Aug 2, 2024 at 12:11 AM
    caribe makaira
    Or use main wire to Cargo Lamp and Bed Lamps:
    rchrds likes this.
  10. Aug 2, 2024 at 3:19 PM
    rchrds
    rchrds Well-Known Member
    TN, USA
    2024 Trailhunter
    Ok I want to do something very similar- but with the Prinsu Camp lights- 4x0.4 amps (1.6A total.) Could I build a jumper behind the bed light switch on the trailhunters similar to the Dongar dashcam jumpers and just add a line there without an additional relay? Would the existing circuit tolerate the additional load? I don't have access to wherever these electrical diagrams are coming from. (Where are they, btw?)
  11. Aug 2, 2024 at 3:26 PM
    caribe makaira
    If I went your route, I'd still add the relay. Even for low amps. Those jumpers are a neat solution as long as they are secured (taped to adjacent wire) in place.
    https://techinfo.toyota.com/
    Is the paying site for Taco diagrams.
    rchrds[QUOTED] likes this.
  12. Aug 2, 2024 at 3:30 PM
    rchrds
    TN, USA
    2024 Trailhunter
    Thanks for the TIS link- I had seen it in the past somewhere.
    If I run a relay- where is the best place to tap (ideally without those terrible clamp on wire taps) for switched power?
  13. Aug 2, 2024 at 3:47 PM
    caribe makaira
    Use an add a fuse type gadget. But you'd loose the fuse cover. I don't know if anyone makes a taller cover yet.
    USB(s) looks like a candidate.
    If you use a battery source (not IGN) then the added lamps can work with dash Cargo switch fused power as trigger at anytime.
  14. Aug 3, 2024 at 8:58 AM
    rchrds
    TN, USA
    2024 Trailhunter
    Wouldn't each of those accessory switches in the cab have a switched DC power in line? Seems like each of those switches is rated for between 5 and 15 amps, based on the supplied wiring harnesses- if I keep the loads under those rated for the switches- seems like it would be much easier to just draw from one of those switches, plus it's a very short wire run.
  15. Aug 3, 2024 at 9:01 AM
    caribe makaira
    Which particular accessory switches are you referring to? The ones that say AUX? They activate the corresponding relay.
  16. Aug 3, 2024 at 9:18 AM
    rchrds
    TN, USA
    2024 Trailhunter
    Right- but if you connect into the harness before the switch- do they actually have relays, or is it direct power through the switch?
  17. Aug 3, 2024 at 9:19 AM
    caribe makaira
    Toyota doesn't use a switch to run fused power, always a relay in the circuit.
    Unused connectors
  18. Aug 3, 2024 at 1:47 PM
    rchrds
    TN, USA
    2024 Trailhunter
    tha
    Thanks, looks like I need to catch up on that other thread.
  19. Aug 4, 2024 at 11:41 PM
    caribe makaira
    If you're skilled and daring, this is another option:
    Finding Junction connector Q35 and adding a terminal. No cutting into wires or harness.
