Puddle light install and review.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rising Eagle, Sep 22, 2016.
  1. Sep 22, 2016 at 11:58 AM
    Rising Eagle
    Rising Eagle [OP] Well-Known Member
    Berkshires MA
    2020 DCSB OR
    So I installed a set of puddle lights I picked up on fleabay from a toyota dealership. The links below are the install instructions and where you can buy the kit at a cheaper price.
    The install is very doable but it is a pain in the ass.
    Link:
    http://toyotaparts.sparkstoyota.com/displayparts.php?Mdl_dtl=1021&Part_cat=24&parts_id=5488
    Install instructions:
    http://toyotaparts.sparkstoyota.com/install/00016-00069-TACOinst.pdf
    Overall impressions is the kit is pretty solid and worth the $143. The lights and wiring are quality. The instructions get the job done but there are a few improvements needed in the graphics in identifying where to tap into a wiring harness.
    A few issues I ran into was actually mounting the lights to the pinch weld underneath the truck. If you have sliders or step bars it makes the mounting extremely difficult. You will need a right angle drill to drill from the inboard side. Space between the frame rail and pinch weld is tight.
    Don't use a Dewalt black carbide bit. They chew up too quick.
    Use a Milwaukee titanium bit to drill through the pinch weld
    Mount the LED undercarriage lights and run the wires underneath according to instructions. Once the wires are run up through the drain plugs and are inside, run the passenger side wires to the drivers side underneath the carpet. (Pain in the ass).
    This kit taps into the dome light. The best place to tap into the dome light is the IN1 connector that is located in the drivers side A pillar. The yellow and blue wire are the two wires in the harness needed.
    After everything is connected, button everything back up.
    End result looks like this:
    Bottom-line: This kit is decent and looks pretty good. It is not overly difficult if you follow the instructions. The biggest pain in the ass is drilling into the pinch weld and running the wires.
  2. Sep 22, 2016 at 12:36 PM
    rrentrop
    rrentrop TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Thanks for the write up and pics. I'll be installing mine soon.
  3. Sep 22, 2016 at 11:09 PM
    Fast00
    Fast00 New Member
    Baton Rouge,La.
    '10 MGM Double cab sport
    Did this kit come with the foot well lights too? happen to get a pic if they did?
  4. Sep 22, 2016 at 11:15 PM
    Rising Eagle
    Berkshires MA
    2020 DCSB OR
    It did come with footwell lights. In the first pic, The two bags on top of the wires are the footwell lights.
  5. Sep 22, 2016 at 11:19 PM
    Fast00
    Fast00 New Member
    Baton Rouge,La.
    Thanks! I think you just made my mind up.
    Rising Eagle[OP] likes this.
  6. Sep 23, 2016 at 5:15 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Agreed, these lights are nice. Thanks for the install pics.
    As much as I enjoy modding my vehicles, I'm glad I ordered them with the truck. :D
  7. Sep 23, 2016 at 7:56 AM
    foxhound_69
    foxhound_69 Well-Known Member
    Culpeper, VA
    18 DCSB OR Cement
    Thanks for the detailed write-up, now know what I have to look forward to!!
  8. Sep 26, 2016 at 9:44 AM
    rrentrop
    Rich
    Orange County, CA
    Installed the kit yesterday. It took a while, but overall it is a very well designed kit with exceptional instructions (must be downloaded separately via previous post on this thread). I have a rattle down in the kick panel due to insufficient tie-ups of the wires so be sure that everything is snug before putting the panels back on.
    DanishTaco and gpb like this.
  9. Sep 26, 2016 at 9:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Interesting accessory pack.
    Where do the in cab lights mount? Is there a specific place for them, or do you pick your own spot?
    Can you snap some clearer shots of the actual install points, inside and out?
    What I'm trying to figure out is if this kit is doable on a 2nd gen. Don't see why it wouldn't be, but would still like to see the install.
    Thanks!
    shakerhood likes this.
  10. Sep 26, 2016 at 10:14 AM
    rrentrop
    Rich
    Orange County, CA
    The passenger side foot well light is simply ziptied to the blower wire bundle under the dash. The driver side is plastic-revited to the panel under the steering wheel. The external lights are bolted to the pinch weld. I don't see why it wouldn't work on a 2nd gen as long as you can identify the four wires to T-tap. The instructions has some pictures that you might be able to use a reference for your 2nd gen.
    opentang likes this.
  11. Sep 28, 2016 at 6:54 AM
    incredibillhulk
    incredibillhulk Don't Panic
    Bill
    North Carolina
    2013 DCSB MGM
    In the works.
    Thanks very much for your feedback on the kit and instructions! My employer manufacturers these at our plant in Laurinburg, NC. Here's a couple pictures of our production line where we surface mount the LED to the boards, fill the lamp assembly with epoxy for weatherproofing, program the LED control modules, run end-of-line testing, and package them for shipment to Toyota:
  12. Sep 28, 2016 at 6:56 AM
    gpb
    Atlanta
    Cool, thanks for posting. I definitely enjoy my set, glad I got them.
  13. Sep 28, 2016 at 7:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    I read the instructions you linked. I do think they'll work fine on a 2gen, and lots of other vehicles, if one can determine the dome circuit. If I break down and have my old Highlander repainted, I may gussy it up with a set of these too.
    I'm thinking the floor lights could mount on either side of the console. Remove, make holes (like for under steering wheel panel) and mount from backside. Should look very OE, nice and tidy.
  14. Sep 28, 2016 at 7:14 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    150 bucks?? I did mine for $8
  15. Sep 30, 2016 at 10:39 AM
    rmunk43
    rmunk43 Member
    Auburn, CA
    2016 Tacoma TRD Sport Dblcab 4X4
    Couple of questions - the puddle light package from Sparks was only puddle light, did you buy floor lights separate?
    I'm not clear how the passenger side puddle light wires get to the driver side for connection, can you explain please?
  16. Sep 30, 2016 at 10:57 AM
    gpb
    Atlanta
  17. Sep 30, 2016 at 4:12 PM
    Rising Eagle
    Berkshires MA
    2020 DCSB OR
    Floor lights come with it.
    The passenger side wires run into the cab on the passenger side through a rubber drain plug. You then have to run the wires under the carpet from the passenger side to the drivers side. It is a little bit of a pain but completely doable.
  18. Nov 11, 2016 at 10:21 AM
    rrentrop
    Rich
    Orange County, CA
    A nice feature with these puddle lights is that they come on automatically as you approach the driver's door when the truck is locked (and you have your key fob, of course).
  19. Dec 4, 2016 at 8:24 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Can anyone hats thinking about doing these post a pic of the location in relation to the sliders? I'm ready to install these, wa to get it done before I install sliders, but don't want to install them and have the sliders supports/mounts block the lights.
  20. Dec 4, 2016 at 8:28 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    They mount to the pinch weld, so they are not in the way of sliders at all. Sliders bolt to the frame. If you install AFTER the sliders, just buy a drill bit extender for like $10 to get past the sliders.
