Puddle light install and review.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rising Eagle, Sep 22, 2016.
  1. May 17, 2021 at 4:45 PM
    #61
    Chad365
    Chad365 Member
    MGM 2019 TRD OFFROAD , SB,DC
    RC 3” , 285/70/17
    Does anyone have these puddle lights and the oem bed lights also installed ? And issues if any ?
    Thinking of trying to do them both at the same time
  2. May 17, 2021 at 4:47 PM
    #62
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    My 2020 came with both port installed. Absolutely zero issues.
    gsubioguy and Chad365[QUOTED] like this.
  3. Aug 6, 2021 at 11:26 PM
    #63
    TacoJohn85
    TacoJohn85 Member
    Need some help. Started installing this kit tonight and had some issues with the connections into the harness in the a pillar. I have a 2017 TRD sport and I’m not sure if I’m reading the instructions incorrectly but it doesn’t seem like my connector matches the instructions. The wires seem to have a miscolored over the years and I see several yellow wires and several “bluish” wires. I’ve tried a couple combinations with no luck. Can anyone help clarify which wires I should tap?5FF14467-BAA9-471D-8109-01DB8DF23A17.jpg86B92001-45FF-4F8E-A0F4-F1AB1131CC65.jpgD628E6D6-1033-4E7C-ACE8-992B9F4752D9.jpg
  4. Aug 6, 2021 at 11:59 PM
    #64
    caribe makaira
    Caribbean, Puerto Rico
    Try these:
    TacoSportTRD likes this.
  5. Aug 7, 2021 at 1:02 AM
    #65
    Chad365
    Chad365 Member
    RC 3” , 285/70/17
    Yup I went with the numbers as well , just make sure the orientation is correct when looking at the numbers
    In all your pics it seems like your are tapping the wire on the wrong side.
  6. Aug 7, 2021 at 2:53 AM
    #66
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    The wrong side sounds correct. You need to tap the lower plug, the current flowes upward so the hot side is the lower part of the plug using this pic on the right.
  7. Aug 7, 2021 at 4:03 AM
    #67
    caribe makaira
    Fellas, it's a tap. Above or below makes no difference. Also, all drawings of Toyota connectors are meant to be "read" as one looks into the connector, not the wire side.
  8. Aug 7, 2021 at 4:11 AM
    #68
    TacoSportTRD
    Michigan
    True, it makes no difference "if" the plug connectors are connected, but was that the case here?
  9. Aug 7, 2021 at 5:47 AM
    #69
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    My humble opinion is to not do two electrical mods at the same time. Do one, then test it until you're satisfied with it. If a problem occurs, it'll be twice as hard to trouble shoot otherwise.
    gsubioguy likes this.
  10. Aug 7, 2021 at 7:44 AM
    #70
    TacoJohn85
    TacoJohn85 Member
    I appreciate the help! So I made that change to the taps at the connector in the a pillar and now the floor well lights come on with ignition only and the puddle lights do not come on at all. I think I have these other connections correct but please double check me. These are the connections in the kick panel. 2FCAB1B1-8343-44C3-A661-B2563BE01CF4.jpgD5BDC0BF-D958-4251-BF07-95B523045F50.jpg
  11. Aug 7, 2021 at 10:01 AM
    #71
    Chad365
    Chad365 Member
    RC 3” , 285/70/17
    It’s hard to tell from that pic, but it seems like it’s the same issue as before , you are tapping #5 or #6 wire instead of #1.
    Also Iam assuming your dome lights did turn on when you approached the truck before you did the puddle light mod correct ?
  12. Aug 7, 2021 at 10:34 AM
    #72
    TacoJohn85
    TacoJohn85 Member
    I thought these diagrams were viewed from the pin side so #1 on the pin side would be top right on the wire side. I don’t recall if my dome light would come on as I approached. It obviously comes on when i unlock or open the door, so the foot well lights nor puddle lights are coming on when the dome light is on. However the footwell lights will come on now if I start the truck.
  13. Aug 7, 2021 at 10:43 AM
    #73
    Chad365
    Chad365 Member
    RC 3” , 285/70/17
    upload_2021-8-7_14-3-59.jpg Edited : hold on I’ll take a look at my connections and double check
    Seems like you tapped into the right wire , I have the lights and that works for me
  14. Aug 7, 2021 at 10:57 AM
    #74
    TacoSportTRD
    Michigan
    On the right side pic the pins are shown from the connection side. Just make sure that the connection clip orientation is at the top.
    Notice the numbers 1&9 are flipped.
    And it is a view of the bottom connector.
    The pic on the left color's are incorrect but the orientation is correct.
    I have the 2017 Sport also and when I did this mod the wire colors to tap into were yellow and blue. When I walk up to the drivers door the dome lights will come on with the new puddle lights and the foot well lights.
    The ignition does not have to be on.
    I didn't tap into any wires in the foot well, just the A pillar.
  15. Aug 7, 2021 at 11:11 AM
    #75
    Chad365
    Chad365 Member
    RC 3” , 285/70/17
    9977758C-B53A-4064-AAED-5B8E5531296B.jpg I would check the connections to the led control module make sure it’s clicked in all the way.
  16. Aug 7, 2021 at 1:41 PM
    #76
    Keokie30
    Keokie30 Active Member
    2016 White Tacoma Limited 4x4
    anyone intetrested in buy Meso custom new
    Tacoma Puddle Pods lighhts
    Asking #100.00
    AMSK.505 and gsubioguy like this.
  17. Aug 7, 2021 at 5:00 PM
    #77
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    And now the MESO's show up! Haha I'd never been able to get to the site in time after getting the in stock notification emails.
  18. Aug 7, 2021 at 6:39 PM
    #78
    Keokie30
    Well i have this one I'm selling. I don't need it since I sold my truck.
  19. Aug 7, 2021 at 9:20 PM
    #79
    TacoJohn85
    TacoJohn85 Member
    So finally got the puddle lights and footwell lights working. I found this seemingly updated instruction sheet for the kit.
    http://toyotaparts.sparkstoyota.com/install/00016-00069-2021-tacoma.pdf
    I also found that I had to replace the red t taps in the a pillar, on the ground, and on the newly specified gray wire with the black t taps that came with the kit but were not called for in the instructions. I found the red t taps were too large for the small gauge wires, they were not cutting through the insulation and making contact with the wire. The black have a smaller notch and work with those wires.
    So those are working but in the process somehow knocked out power circuit that is usually hot with the truck off…i.e. the door locks, internal and external lights, key fob. The truck will still go to the mode if you press the start button 1 time and the radio comes on, and then it will go to full acc mode with the second push and start with the brake being held. In acc mode and with the ign on everything seems to work properly, it’s just when the truck is off. I haven’t been able to find a blown fuse. So scratching my head a bit.
    Vikter likes this.
  20. Sep 11, 2021 at 4:30 AM
    #80
    Ahomeofbones
    Ahomeofbones Member Well-Known
    2021 TRD OR
    Really late here but by chance are you still selling those puddle pods?
