puffing sound when I rev the engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACK, Feb 2, 2011.
  1. Feb 2, 2011 at 6:49 PM
    TACK
    TACK [OP] Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, Sickspeed shift knob, mud flap delete, white lithium grease mod for creaky clutch pedal
    If I give the gas a quick punch and rev the engine (while idling or while driving) there is a pretty obvious quick "chh" sound coming from the engine immediately before it revs.
    Truck idles fine, drives great, no check engine light or any problems. I'm not sure if this is a new thing or if it's always done this and I'm just now noticing it. I have about 7,000 miles on it.
    Is this normal? Do they all do this? [​IMG]
  2. Feb 2, 2011 at 6:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Its the intake you're hearing. Its normal
  3. Feb 2, 2011 at 6:55 PM
    TACK
    Nevada
    Thank you!!
  4. Feb 11, 2011 at 3:47 PM
    ADVBedouin
    ADVBedouin Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    Yep mine does it too...sort of a cough, but only when I first start it in the mornings & not every time. It shouldn't do this & I'll try to find out why.
