Pull or not
Discussion in 'New Members' started by Stock08, Oct 31, 2023.
  1. Oct 31, 2023 at 11:12 AM
    Stock08
    Stock08 [OP] New Member
    Doug
    2008 Tacoma
    None
    I have a 2008 Tacoma. Truck will trun over but not start after over heating. I have done a compression test, number are front to back 60,10,10 and 62. I have also a done a leakage test numbers were 70% and lower.
    My question is should I tear down or just replace the motor? I'm just looking for thoughts. Truck belongs to my mother in law I know replacement of the enqould be the quickest repair. Thanks in advance.
    buckhuntin-tacoma likes this.
  2. Oct 31, 2023 at 11:20 AM
    Stock08
    Doug
    2008 Tacoma
    None
    Oh, when I say the truck over heated, it was hot hot enough to blow the radiator cap off.
  3. Oct 31, 2023 at 11:23 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Those are dismal compression test numbers. I’d suspect the head is warped if I had to throw darts at it.
    You might pull the head and see just how bad it is, but it’ll be faster to find another motor.
    SR-71A and buckhuntin-tacoma like this.
  4. Oct 31, 2023 at 11:23 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If it has good bones otherwise, I'd swap it out with a used or rebuilt motor, whatever you can find.
  5. Oct 31, 2023 at 1:04 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    TomTwo likes this.
  6. Oct 31, 2023 at 2:00 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Pull the head and see if the cylinders are still smooth. If the cylinders are not scratched and there is no evidence of seizure (metal/aluminum deposits on cylinder walls) then replace the head. Your local machine shop can tell you if your old one can be saved. That may get you going till you can get an engine core and rebuild it.
    0xDEADBEEF likes this.
  7. Oct 31, 2023 at 2:06 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I would tear it down and evaluate it and have the head checked by a competent shop. Check the cylinder walls etc. you know for sure it has a blown head gasket. Who knows you might get lucky :pccoffee:
    Taco y mas likes this.
  8. Oct 31, 2023 at 2:19 PM
    Bishop84
    Bishop84 Well-Known Member
    As a tech I wouldn’t bother, it’s cooked, aluminum has a memory and even if it got machined it would still warp again.
    Id go straight to a used engine quote.
  9. Oct 31, 2023 at 2:34 PM
    TomTwo
    Bill
    I-85 Southbound
    As a retired Mechanic and former Maintenance Director. If you are not going the route I suggested above, I would not waste my time with a used Engine. I would purchase a Reman engine with a Warranty.
  10. Oct 31, 2023 at 3:13 PM
    Bishop84
    We don’t have reman Toyota engines here. A short block with heads would be probably 13k
  11. Oct 31, 2023 at 3:34 PM
    TomTwo
    Bill
    I-85 Southbound
    You might get lucky and find one at a junk yard that came from a truck that had been hit in the rear but you will also need the ECM
  12. Oct 31, 2023 at 3:36 PM
    Bishop84
    With Toyota v6 we’ve had lots of luck. Haven’t had a bad engine yet from our wrecker.
    The 4 bangers are a crap shoot and we don’t do used anymore. Oil consumption from ring lands is super common.
    TomTwo[QUOTED] likes this.
