Pull trigger on 285/70/17 BFG AT's?
Discussion in 'Wheels & Tires' started by KRich, Apr 4, 2012.
  1. Apr 4, 2012 at 10:14 AM
    KRich
    KRich [OP] Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Hi all,
    I am ready to buy some dedicated non-winter use tires and have been leaning towards the 285/70/17 BFG A/T KO's. I have the stock 17" TRD sport rims with Bilstein 5100's on all four tires set at 2.5 in the front and a Toytec AAL for TSB in the rear. I also have 1.25 spidertrax spacers all the way around. I have a few questions before I pull the trigger:
    My understanding with this setup is that I will probably have to remove the front mudflaps and do some minor to moderate trimming to eliminate most if not all rub?
    I am debating between D and E load range and it looks like there isn't a big weight difference per tire but that the D range may use a softer compound for the mud and snow rating, since I won't be using these for winter, would I get longer tread life with the E?
    Lastly, I have been trying to overlook this part but with gas prices the way they are, how much worse are these tires going to make my gas mileage? I currently have 265/70/17 Nokian Hakka LT Load E studded winter tires on the truck and don't find the gas mileage that bad but these tires are only 45 lbs each compared to the 55-58 lbs each that the BFGs will be.
    Sorry for the long post, but I really appreciate any info that you guys can give me.
    cheers,
    Kyle
  2. Apr 4, 2012 at 10:17 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have Load e a lot of people complain that there to stiff but just keep them at 32-34 psi and there fine I've put 20000 hard miles on my there just about half way Tread
  3. Apr 4, 2012 at 10:28 PM
    KRich
    BC, Canada
    Bumpity bump bump, leaning towards Load D now
  4. Apr 4, 2012 at 10:44 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Load D will be lighter/better for mpg. Im not sure if it will be noticeable though.
  5. Apr 8, 2012 at 2:41 PM
    KRich
    BC, Canada
    bump
  6. Apr 8, 2012 at 2:46 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I just got the D rated BFGs about 3 weeks ago! Love them! I don't tow much so I thought the E would be overkill!
    Pic
  7. Apr 8, 2012 at 9:50 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    you will probably have to do the CMC as well.
  8. Apr 8, 2012 at 10:45 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    What kind of front springs are you running with those billys turned up to 2.5?
  9. Apr 9, 2012 at 12:12 AM
    KRich
    BC, Canada
    Still running the stock springs at this point. I want to order the tires tomorrow but I'm starting to wonder if I should get the BFG's in a 275 since they do make that size and it might be better for mileage and less trimming etc
  10. Apr 9, 2012 at 7:03 AM
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
    I am also interested in BFGs in 275s...if you order them...can you post up some pics after install? thanks
  11. Apr 9, 2012 at 8:24 PM
    KRich
    BC, Canada
    Just ordered the 285's for install on Thursday. Have seen a few posts from guys that got 275s and wished they had gone bigger so I am throwing common sense to the wind and going for it. The way gas prices are going, this truck will probably only be affordable to drive for a few more years :p.
  12. Apr 9, 2012 at 8:30 PM
    VancouverTaco
    VancouverTaco Well-Known Member
    Cole
    Vancouver, BC
    08 SR5
    Billy's 5100 all 'round, 2.5 front
    I have the exact same set up as you, billy's 5100 set to 2.5 and billys in the rear. I have the 285/75r16 AT KO's load range D. I love them, the load range E would have been overkill. I doubt you will regret these tires.
    As far as trimming goes - I had to remove my front and rear mud flaps, and trim some minor plastic, which wasnt a big deal because you can barely notice.
  13. Apr 9, 2012 at 8:34 PM
    VancouverTaco
    Cole
    Vancouver, BC
    08 SR5
    Also, the load range D is actually wider than the load range E. The E has a slightly larger diameter
  14. Apr 9, 2012 at 8:38 PM
    lossscause
    lossscause Well-Known Member
    Southwest Ohio
    2001 Taco DC 4x4
    Eibach coils/Bilstein 5100's, 2" block, 17x7.5 Tundra Wheels, 285/70/17 BFG AT, 1.25" All-Pro Spacers, AirLift Bags w/On Board Compressor
    I've got 285/70/17 BFG D rated and love them. Great tire.
  15. Apr 9, 2012 at 8:40 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    I have 285 BFGs with a 3" lift and just had to trim the inner black mud guard a bit. They look great and ride way softer then the toyo's i had before.
  16. Apr 10, 2012 at 7:21 AM
    avocent
    avocent New Member
    This is about the same question I have. Want to go 285, but I don't want to chop the cab if I don't have to. I have the toytec ULK with LR UCAs up front, and toytec TSB AAL and 5100s in the rear, and spidertrax on all 4. It's sitting 2.5 to 3 in up and currently running 255/75r17 BFG MT KMs. Looking at 285/70r17 BFG ATs. Cannot find a definite answer on the chop. I too might go 275 if I don't find the answer.
  17. Apr 12, 2012 at 6:56 PM
    KRich
    BC, Canada
    Got the new shoes installed today and wow do they look great! I did remove the front mudflaps and trim some of the inner fender and was hoping that I was all clear but then did manage to scrape when going over a bump and turning at the same time so may have to trim a bit more. If that all works out well I think I am going to be a very happy camper! As I have seen posted all over the place here, the 285 does look perfect with the 2.5-3" lift and I don't think I would want to go smaller.
  18. Apr 14, 2012 at 2:33 AM
    rob_s
    rob_s Well-Known Member
    SE FL
    White 2010 DC SB Sport
    where's the pics?!!
  19. Apr 15, 2012 at 6:09 AM
    OneMentalCase
    South Florida
    10 Pyrite LB
    Lets see the pics!!!
  20. Apr 16, 2012 at 7:42 AM
    KRich
    BC, Canada
    I'll see what i can do!
