Pulled a 4x4 blazer
Discussion in 'Off-Roading & Trails' started by Drewboto, Jun 4, 2010.
  1. Jun 4, 2010 at 11:04 AM
    Drewboto
    Drewboto [OP] Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    A few days ago I was playing around on some dirt trails with my brother. As we were leaving the trails, we came across a 4x4 blazer stuck in a mud pit.
    They had dug some deep ruts and the vehicle was sitting on it's axles.
    They asked for help so I drove around behind them and pulled out my recovery strap. They told me to drive around the front and they would hook a winch up to my truck. They looked like experienced off-roaders so I followed instructions. After dodging about a 70 yards of suicide ruts with my 4x2 I got within winching distance at the front . We hooked up the winch to my frame and got to work. They started the winch but the only thing that moved was my truck. My little '04 base reg cab came close to swimming in the mud with them. So they tell me to get in the truck and pull them out. So I hop in and put it in gear. Pull them a couple feet to my surprise, although my tires were spinning a bit. Apparently they were stupid or something because when they were almost out, they loosened and tightened the winch while rocking their rig forwards and backwards while I was pulling. Whenever I stopped pulling, they tell me to pull while they're switching between forward and reverse and screwing around with the winch. They're efforts were useless and the little taco pulled them out. We chatted for bit then I left. I can't believe they jarred, jerked and used their winch cable like that. Dangerous
    Lesson learned: The rescue driver calls the shots how things get done.
    Sorry about not having pics.
  2. Jun 4, 2010 at 2:17 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    your truck= your rules. if i come over to pull you out, i tell you how im pulling you out. I dont let other people tell me what to do with my truck. :)
  3. Jun 4, 2010 at 7:37 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Well, experienced offroaders they are not. You never use a winch for recovery like that. The brake on the winch isn't designed for that kind of use. A snatch strap is a better option in that situation if the winch cable isn't long enough to reach a fixed or anchor point.
    Had they asked to be recovered and wanted to attach a winch line to my rig like that I would have told them see ya.
    You need a stout recovery point on the back of your truck and the frame is not an option in my book
  4. Jun 5, 2010 at 4:41 AM
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
    Have the person being rescued hook up their end of the strap or winch. I usually tell them that whatever they hook the cable to is coming out and its up to them to make sure the rest of their vehicle comes with it.
    x2 on a winch not being a recovery point. Use the snatch strap!
  5. Jan 22, 2011 at 1:03 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    X2 :)[​IMG]:D
  6. Jan 22, 2011 at 8:39 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    wow op, that's pretty cool.
  7. Jan 22, 2011 at 8:43 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Was this a full-size Blazer or an S-10 Blazer? The latter should be relatively good with the right tires.
  8. Jan 22, 2011 at 8:46 PM
    IndianTaco
    IndianTaco Well-Known Member
    looks like a old ford to me!
    nice work tho
  9. Jan 22, 2011 at 8:57 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    The picture was of a Ford F350 4 door Bronco. & This was the first time I seen a rig like this.
