Pulled Fuse while running
Discussion in '1st Gen. Tacomas (1995-2004)' started by JayARRGHH, Jul 17, 2011.
  1. Jul 17, 2011 at 4:36 PM
    JayARRGHH
    JayARRGHH [OP] Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    I grabbed the wrong fuse while the engine was running, turns out it was the ignition fuse, engine sputtered out, now it wont start. I tried replacing the fuse. Nothing. I disconnected the battery for 20 mins. Nothing. I checked the fusable link between the fusebox and the battery. Nothing. Can someone help me out? My trucks an expensive learning curve for me.
  2. Jul 17, 2011 at 4:47 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Is it cranking?
    What is it doing..? Symptom wise..
    Check your 15A EFI fuse.
  3. Jul 17, 2011 at 4:51 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
  4. Jul 17, 2011 at 4:52 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Oh sorry i forgot to add that, it is NOT cranking, absolutely nothing. Also right before that i was wirin up my 55w halogen worklights and it blew something because the dash/radio/horn/hazards etc wont work but i checked the fuses and none of them are blown which led me to unplugging all of the fuses.
  5. Jul 17, 2011 at 4:53 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    thats what my gf was doing while i slowy made everything FUBAR
  6. Jul 17, 2011 at 4:56 PM
    Superx2
    Joey
    Iowa
    i would double check that you have them in all the way and that its in park if its a auto, and check the fuse again.
  7. Jul 17, 2011 at 4:57 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Check your 15A DOME fuse under hood if radio isn't working..
  8. Jul 17, 2011 at 4:58 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    did that too :/ I read somewhere that if theres a check engine light on you need to clear the codes first but i cant tell if there is because whatever happened with the gauges/accessory power issue.
  9. Jul 17, 2011 at 4:58 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    If it's not cranking at all, try the 15A IGN and 7.5A IGN under the dash.
  10. Jul 17, 2011 at 5:00 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    i think I did but i need to double check now. If there are any other suggestions or worst case scenarios would be great because im down the street from it, i had to take a break before i smashed my windshield.
  11. Jul 17, 2011 at 5:02 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Radio is tied into dome circuit.
    Also, under dash is a 10A TURN circuit..check the fuse.
    Also, under the hood is a 15A HORN fuse.
    Far as it not cranking, it's gotta be one of your fuses..check both IGN fuses again.
  12. Jul 17, 2011 at 9:17 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Alright, literally every fuse has been swapped and still not working. another update, with the key on and foot on the brake i cannot take it out of park. I don't know if that helps the diagnostic at all.
  13. Jul 18, 2011 at 5:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    So you have checked all the fuses in both fuse boxes?
  14. Jul 18, 2011 at 10:35 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Interesting.. :popcorn:
  15. Jul 18, 2011 at 10:44 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    yup :/
  16. Jul 18, 2011 at 10:51 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Is it making a clicking noise?
    or no noise?
    :eek:
  17. Jul 18, 2011 at 11:15 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Initially no. We tried tapping the starter too and nothing, we also tried to jump the relay with a pair of needle nose :/ nothing as well. Is a fried computer in the realm of possibility?
  18. Jul 18, 2011 at 11:24 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You might want to check some of the big body fuses in the box under the hood sounds like you lost a lot of stuff all at once.
  19. Jul 18, 2011 at 11:31 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Did you blow the 120A Alt fuse? You have to basically take apart the fuse block under the hood to get to it.
  20. Jul 18, 2011 at 11:44 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Do you have 12 at the solenoid when you turn the key?
