Pulled out of snow, think I pulled a sensor
Discussion in 'Technical Chat' started by Jena, Mar 1, 2013.
  1. Mar 1, 2013 at 8:40 AM
    Jena
    Jena [OP] New Member
    All Over
    2010 Tacoma, '93 Pickup
    Hello.
    I have a 2010 Tacoma 4WD, 4 cyl, manual trans. I got stuck "head first" in the snow and was pulled out backwards. The mud flap on the drivers front was ripped off and I probably something else as well.
    My air bag light, check engine, and a couple other lights are on, speedometer/odometer won't work. Blinkers don't work, but I have lights and brake lights. Seat belt reminder light comes on, but the dinger doesn't work. The traction control thing doesn't ding either. The heater vent switch doesn't work.
    I tried resetting it using the scanner thing at the auto parts store, no effect.
    I figure I pulled some sensor something off, but don't see anything obvious when I look around the wheels and underneath. Where else should I look?
    I have to keep driving until I can get it fixed (probably at least several days). Is that going to hurt it?
    Is my odometer going to appear to be tampered with after this? How do I fix that so I don't get in trouble when I go to sell it someday?
    Thanks!
    Jena
  2. Mar 1, 2013 at 8:47 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    try pulling the battery terminals off for 30 minutes. then reconnecting. should do a good reset. your stereo presets will be lost however.
  3. Mar 2, 2013 at 11:30 AM
    Jena
    All Over
    There was a blown ignition fuse so I replaced that and also took the battery cables off for good measure. Gonna go check it in a bit and hopefully it's fixed!
  4. Mar 2, 2013 at 1:53 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Check all of the fuses.
    Get the code read, not just clear it.
  5. Mar 2, 2013 at 2:52 PM
    OldFatGuy
    OldFatGuy Well-Known Member
    Robert
    Greenville, NC
    2012 4WD double cab with minor mods
    Flow Master 50 Series dual K&N Filter Cheap Toyota Skid Plate (better than Nothing) 2.5 Hell Bent leveling Kit 1.0 blocks on rear 285-75-16 BFG KO High Performance Bed Mat De-Badged Westin Light bar -W/ 3 KC 100watt slim lights
    Let us know what it was. Just in case it happens to someone else.
