Pulled these out of my AC vents
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StickShifty, Jan 7, 2013.
  1. Jan 7, 2013 at 6:56 AM
    StickShifty
    StickShifty [OP] Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    a month or two ago i noticed i had a piece of foam blocking the air flow in one of the center vents. so today i pulled it out, and noticed that 3 out of the 4 front vents had foam that came loose and was blocking the airflow.
    In the summer I noticed that my AC system was not cooling as much as other cars. To get the truck cool i had to use the recirculate button. I am going to say that this was my issue, not enough airflow.
    Has anyone ever had this issue, i found it interesting that 3 out of the 4 front vents were blocked, and this truck is still basically new.
    I attached a picture for your viewing pleasure.
  2. Jan 7, 2013 at 7:00 AM
    Namyo
    Namyo -
  3. Jan 7, 2013 at 7:01 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    hmmm....interesting.
    Wonder where the source of the foam is.
  4. Jan 7, 2013 at 7:10 AM
    StickShifty
    New Jersey
    2012 AC 4WD 6SPD
    idk, they dont look too important, lol. i am curious to see if someone knows where they are from (like deep inside the system or something to keep the sides of the radio from getting too hot or cold).
  5. Jan 7, 2013 at 7:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    They most likely the foam surrounding the ductwork so it doesn't rattle against the vents in the dash. Odd that they would have shifted on you.
    Have you had your dashboard worked on? Maybe a stereo installation shop?
  6. Jan 7, 2013 at 7:20 AM
    StickShifty
    New Jersey
    2012 AC 4WD 6SPD
    inside of the truck is bone stock. just have one hot wire coming from the fuse panel under the steering wheel that goes under the center stack, back under the center cup holders, down under the passengers seat. to do this i had to take out the center console.
  7. Jan 7, 2013 at 7:21 AM
    JayDirt
    JayDirt I owe it all to little chocolate donuts
  8. Jan 7, 2013 at 7:22 AM
    StickShifty
    New Jersey
    2012 AC 4WD 6SPD
    haha. if the vents didn't have grills, it would have been like that.
  9. Jan 7, 2013 at 7:25 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    No!!! last time i saw those freakin' things was when i owned a '92 VW Corrado. What a PITA to remove and they were brittle by that time making a mess.
  10. Jan 7, 2013 at 7:34 AM
    Spitz Stang
    Spitz Stang Well-Known Member
    Mark
    Houston, TX
    2012 DC TRD OR 4x4
    OME 885 / Dakar,5100's, 265/65-16
    My truck had the same problem. I noticed the foam in one of the vents the day I picked it up. Service guy said that the foam was suppose to be stuck to the inside of the vent to seal it. They ordered a new vent...which was on a 7-9 day backorder...and installed it under warranty.
    Mine was only on one vent though not 3 :eek:.
