Pulled Transmission, now have High Temp Trans Warni
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rtzx9r, Aug 26, 2023.
  1. Aug 26, 2023 at 4:33 PM
    rtzx9r
    rtzx9r [OP] Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    We did the dreaded back of the engine coolant pipe replacement. All went smooth and we pulled the transmission as part of the process. Prior to pulling, I drained 3 qts from its well as the antifreeze (1 gallon) per Toyota instructions. Put back together. Added 3 qts of trans fluid and topped off the radiator (squeezed upper rad hose etc).
    Upon starting the truck, I get a flashing high temp transmission fluid warning flashing on the dash (truck is cold, no leaks underneath). I’m assuming the coolant and atf “pump” on the passenger side of the transmission has some air in it and is giving me a false warning.
    Any ideas? Truck goes into R and D and moves but the changes are a bit jerky. Is there a bleed procedure, or should I pin open the trans cooler to get things moving?
    Thanks.
  2. Aug 26, 2023 at 4:39 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sure you didn't pinch a wire or something?
    rtzx9r[OP] likes this.
  3. Aug 26, 2023 at 5:09 PM
    rtzx9r
    Bueller
    2016 TRD Sport
    I don’t think we pinched anything, though entirely possible.
  4. Aug 26, 2023 at 5:23 PM
    InThePlains
    InThePlains Well-Known Member
  5. Aug 26, 2023 at 5:40 PM
    rtzx9r
    Bueller
    2016 TRD Sport
    Thanks - I have a vacuum bleed system but didn’t use it this time. Not sure there any any pockets that air bubbles get caught in.
  6. Aug 26, 2023 at 5:43 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Have you let it idle in P or N and let the trans and engine get up to temperature? Pretty sure the trans has a sort of thermostat and won't fully move fluid until it's warmed up. Part of the reason you check fluid level between a certain temperature range.
    I'd get it up to temp without putting it in gear. Then follow procedure for checking fluid level.
  7. Aug 26, 2023 at 5:50 PM
    rtzx9r
    Bueller
    2016 TRD Sport
    Haven’t let it in idle as it flashes up the high temp warning maybe 15 seconds after starting it from it sitting overnight. Ran the gear selector thru the range but didn’t want to let it run too l9ng in event something is truly over temp.
    I have done the fluid check level previously….5k miles ago when I did a flush and trans filter. This time around 3qts on the dot came out so I put in 3 QTs of new WS fluid and wasn’t planning to check the level.
    Superdave1.0 likes this.
  8. Aug 26, 2023 at 5:59 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    you have a connection off, misplaced, or a wire cut, if it comes on within seconds of start up. Ski
    joba27n, Superdave1.0 and rtzx9r[OP] like this.
  9. Aug 26, 2023 at 6:01 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    You should obviously check the transmission fluid level at the correct temp to make sure it is filled properly. That said, if it’s flashing high temp 15 seconds after a cold start something else is clearly wrong.
  10. Aug 26, 2023 at 6:03 PM
    Superdave1.0
    SoCal
    Yeah it can't be over temp 15 seconds into start up. I'd double check connections as mentioned. Then proceed with warmup and temp check. But that's just what I would do. I don't want to be responsible for you blowing up your trans.
    tcjacado likes this.
  11. Aug 26, 2023 at 6:22 PM
    rtzx9r
    Bueller
    2016 TRD Sport
    Thanks all - will be happy to check the fluid level once I sort out the warning… it’s a pretty quick process.
  12. Aug 26, 2023 at 6:45 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I would check your electrical connections because yes, the warning that quick doesn't seem right along with typically sensors read in a range and a wide open circuit or a short will produce the extremes for their readings. I don't know how this sensor is wired up so I can't predict if it's shorted out or wire broken but I would say it's one of the two. Check all around the bell-housing for wires and look for any forgotten plugs
  13. Aug 26, 2023 at 7:17 PM
    InThePlains
    You probably miss a plug for the trans temp senor or some sort.
    I replaced mine the weekend before, though I have a manual trans, the wiring plugs were not as straight forward.
  14. Aug 27, 2023 at 10:14 AM
    rtzx9r
    Bueller
    2016 TRD Sport
    Thanks everyone. Ended up being the main harness that plugs into the transmission… the “lever” on it was not secured and it was therefore not fully engaged. Fixed 7 trans dtc’s.
