Pulley? Alternator? Water pump?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, May 24, 2023.
  1. May 24, 2023 at 3:06 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I can hear a rotational sound even in the truck. At first I thought it was the tire/wheel, however now I realize it's under the hood.... I suck at taking these vids. This is two out of five taken. If a shot at something else is needed, lemme know & I'll see what I can do.... Maybe I should just try using the phone....
    https://youtu.be/iC-1ru4HWgg
    https://youtu.be/zW54k0e_S1M
    HondaGM likes this.
  2. May 24, 2023 at 6:44 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I can't hear anything myself, but I'm deaf in one ear and phone microphones aren't the best at picking up these noises. I'd suggest using an automotive stethoscope to try and pinpoint futher. Spraying some soapy water on each pulley one by one (listening for a change/reduction in the noise), can also help. Don't rule out an idler pulley or fan clutch either. Idler pulley tends to go first and more frequently than others, so I'd rule that one out first
    HondaGM likes this.
  3. May 24, 2023 at 6:49 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    What’s up Kristie…so you have 2 drive belts?
  4. May 24, 2023 at 6:59 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Does it make the noise your hearing with the HVAC control on dash in off position?
  5. May 24, 2023 at 7:28 PM
    Kristi with a K
    Western MA
    My AC belt is removed & idler pulley is well secured....
    Nevin likes this.
  6. May 24, 2023 at 7:31 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    It’s gonna be a guess..but it kinda sounds like the alternator…
  7. May 24, 2023 at 7:32 PM
    Kristi with a K
    Western MA
    Yes. I have the PS & Alt belts. No AC belt.
    HondaGM[QUOTED] likes this.
  8. May 24, 2023 at 7:34 PM
    Kristi with a K
    Western MA
    That's what I'm wonderin'. Would it make that whiney noise when the engine is revved? I don't think that got picked up very well on the vid recording.
  9. May 24, 2023 at 7:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You tried loosening the alternator belt or removing it to see if stops
    1997tacomav6 likes this.
  10. May 24, 2023 at 7:37 PM
    Kristi with a K
    Western MA
    No. I can remove the alt belt & still run the truck?
  11. May 24, 2023 at 7:37 PM
    Kristi with a K
    Western MA
    I mean without it overheating?
    HondaGM likes this.
  12. May 24, 2023 at 7:41 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Oh yeah… ..if it’s the alternator you should know within a couple seconds if the noise stops…the power steering / water pump will still be turning
    Wulf and 1997tacomav6 like this.
  13. May 24, 2023 at 7:45 PM
    Kristi with a K
    Western MA
    & I've been calling it the wrong name. Being the fan belt, if the noise stops, wouldn't that also mean it could have something to do with the fan or harmonic balancer?
  14. May 24, 2023 at 7:51 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Well.. you would need to visually check your harmonic balancer… just looking at the video your balancer looks ok…you have 2 belts,one on the fan and alternator,and the other on the fan and power steering pump
  15. May 24, 2023 at 8:04 PM
    Kristi with a K
    Western MA
    Ok. Good. I looked up how to tell if the balancer was off & couldn't find much as far as a visual check....
  16. May 24, 2023 at 8:29 PM
    Kristi with a K
    Western MA
    As I'm watching these, what keeps catching my eye is the closest underside rib of the alt belt. These two vids where taken on two different days, different lighting, yet that rib looks shiny in both. I wonder if the pulley is off or needs to be adjusted....
  17. May 25, 2023 at 7:41 AM
    1997tacomav6
    Denver
    First u need to see which belt is turning the item that's causing the noise to eliminate the other parts.
    Take the alternator belt off and see if the sound goes away.
    It could be the alternator or the fan clutch or the fan bracket bearing.
    If the noise is still there with alternator belt off look at steering pump ,
    The noise could be coming from the timing belt idler pulley too.
    When was the t belt and bearings replaced last?
    You will tell right away when you remove the alternator belt if it's one of those 3 items
    Do you have a mechanic stephiscope?
  18. May 25, 2023 at 10:26 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  19. May 25, 2023 at 10:33 AM
    Kristi with a K
    Western MA
    I do have a stethoscope.
    The timing belt was done around 50,000 miles back. I don’t recall doing any bearings though. Followed Tim’s vid & did everything in it plus the idler pulley….
    1997tacomav6[QUOTED] likes this.
  20. May 25, 2023 at 10:35 AM
    Kristi with a K
    Western MA
    Ha-ha! Just got home, so it’ll be a minute….
