pulley or belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Jun 23, 2009.
  1. Jun 23, 2009 at 2:37 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    truck just hit 55,000 miles and after changing the oil i now got this squeeling noise when the truck is in drive and on slow acceleration. im thinking its either the serpentine belt or the idler pulleys after reading other threads with the same problem. anyone else have their pulleys or belt replaced around this mileage? i was also thinking maybe some oil got on the belt or pulleys and is causing the noise. gonna wait a couple days till i take it to the dealer. any other options?
  2. Jun 23, 2009 at 2:44 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Sounds like the belts to me. Pulleys usually don't squeal. You can check and see if you did get some oil on the belt: Just check the underside of each belt. Also check the tension. If there is no oil and it continues squealing for a few days, give the tensioner a little tighten and see if that does the trick. 55k seems very premature for belt failure. Mine lasted 175k before I replaced them.
  3. Jun 23, 2009 at 2:49 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    When idler or tensioner pulleys start to go bad they usually make a squeek or rattle noise from the bearing. It's most likely the belt. Try squirting a little water on the belt while it's making the noise and see if it temporarily goes away. If it does, replace the belt.
  4. Jun 23, 2009 at 2:49 PM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    idler pulley bearing
  5. Jun 23, 2009 at 2:51 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    Idler/ tensioner pulley.
    just did mine 10K miles ago.
  6. Jun 23, 2009 at 2:54 PM
    tacoskim
    Los Angeles, CA
    Stock
    i dont think its the belt. it wont make the noise if its in park or neutral, only makes it when in drive and slow acceleration. if its the pulleys, they still under the drivetrain warranty?
  7. Jun 23, 2009 at 2:55 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Can you make a recording of the sound?
    edit: the pulleys are not under the power train warranty, but there's only three of them, they're cheap, and SUPER easy to install.
  8. Jun 23, 2009 at 2:55 PM
    tacoskim
    Los Angeles, CA
    Stock
    thanks ill try that. it is a squeek/rattle noise now that i think of it
  9. Jun 23, 2009 at 2:56 PM
    tacoskim
    Los Angeles, CA
    Stock
    i will try when i get home from work, its hard cuz it only does it in D, so ill try to get someone to stand infront of the truck to record the sound
  10. Jun 23, 2009 at 2:56 PM
    brianr
    2010 4x4
    pulleys are covered under the 36K mile warranty.
    It only cost me $50.
  11. Jun 23, 2009 at 2:59 PM
    tacoskim
    Los Angeles, CA
    Stock
    thanks guys for ur quick responses. i think brianr nailed it on the spot, ill update after i talk to my service guy
  12. Jun 23, 2009 at 3:14 PM
    rudy1201
    rudy1201 Member
    smyrna, DE
    2010 Trd sport 4/4
    Its the belt, Just replaced mine at 77,000 miles. I got an online subscription to chilton repair manuel and I was able to print out the info on how to replace the belt myself. They gave me a diagram of how the belt was routed. You have to take of the skid plate and replace it from under the truck. You release the the tension by turning the tensioner counter clockwise until you are able to put a pin ( I used a small screwdriver) in the corresponding holes to hold the tensioner loose. That will alow you to remove and reinstall the belt.When the new belt is on release the tensioner and remove the pin, Reinstall the skid plate and your done. No more squeaks!
  13. Jun 23, 2009 at 9:50 PM
    tacoskim
    Los Angeles, CA
    Stock
    so was under the truck and noticed a leak where the driveshaft meets the tranny. what you think, warped seal?
  14. Jun 23, 2009 at 11:38 PM
    johnecon2001
    Phoenix, AZ
    Are you sure that's where it was leaking from? Not higher up towards the engine?
  15. Jun 24, 2009 at 12:03 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    This is some good advice and I will second it.
    If you spray the belt with some water and your noise does not go away, you most likely have a bad pully. bearing failure in the idler pulleys is a fairly common issue.
    Get it covered if your still under warranty, if not they are inexpensive and an easy DIY fix.
  16. Jun 24, 2009 at 11:19 AM
    tacoskim
    Los Angeles, CA
    Stock
    so just got back from toyota. the mechanic and i looked forever for the sound after he checked the pulleys and belt. so we noticed that the squeek stopped when the hood was up. he thinks its the headlight and thought they were aftermarket cuz of the BHLM. i giggled and told him it was the oem i just painted them, then told him that no way in hell will the headlight make a rattle/squeek noise. so im looking and im checking my URD intake where the bracket conncects to the frame, and turns out i broke a piece of metal that keeps it connected from hitting the whoops to hard this past weekend.:eek: so the connection is kinda loose and makes contact with the metal. im gonna get a longer bolt and get a bigger washer and sandwich is together, hope this works. if not i can always use a zip tie
  17. Jun 24, 2009 at 11:39 AM
    johnecon2001
    Phoenix, AZ
    So what about the oil leak?
  18. Jun 24, 2009 at 11:43 AM
    tacoskim
    Los Angeles, CA
    Stock
    oh yea forgot to mention that (there was a drip where the tranny meets the driveshaft). last night i wiped everything off and it didnt even look like tranny oil, looked like engine oil. i drove it bout 20 miles last night and 10 miles today to the dealer and its still spotless. so im gonna keep an eye on that and if the seal was warped there should be fluid splattered around that area but its clean. im gonna be peeking under there for the next week to make sure.
