Pullin a Ry Ry
Discussion in 'Arizona' started by Phil Dammit, Aug 10, 2012.
  1. Aug 10, 2012 at 4:18 PM
    Phil Dammit
    Phil Dammit [OP] Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    New jobs 50 miles round trip so the lift and 32's are coming off Whitney so it wil only take me 2 gallons per day over rather then 3. Gonna do Enkei RPF1 18's and DJM 3/4 with an added 1" spacer up front and XR leafs in the rear. Anyone local, or someone that is willing to drive out have the DJM kit and wanna trade for my lift kit, wheels, and tires?
  2. Aug 10, 2012 at 4:55 PM
    Infamous Coating
    Infamous Coating Well-Known Member
    Avondale, AZ
    2012 Tacoma prerunner
    4" Maxtrac spindles and a 2" block on the rear
    New to the Tacoma game but will that lift fit my 2012 prerunner? Sorry for the newb question in advance.
  3. Aug 10, 2012 at 6:02 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    No it won't he has a 5 lug
  4. Aug 10, 2012 at 7:00 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Since fuckin when? Imma gonna make the setup match my motaber project get them bitches anodize red powdered. Then save up and repaint whitney.
    Sir the same could be said about my post visit and your sudden want to mid travel......;)
  5. Aug 10, 2012 at 7:03 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yeah, cheapest I can find them are 303 a piece. What offset were you gonna run? I am thinking 9.5 in the rear with 8 up front but the 9.5 only comes in a 45mm or 15mm. You think 45 will line up with the bed?
    LMAO, your hardness behind the screen amuses me. And dont be raggin on whit, she's a saint.
  6. Aug 10, 2012 at 7:15 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well hmmmm, 8.5 runs a 30+ and the 9.5 run from 15, 38, and 45. probably go with the 15 and work on aquiring or machining a 15mm spacer. I never heard what happened when you tried to roll your bedsides. How bad was it? I want stagered, personaly think stagered looks better. You got about another inch and a half on the inside with those XR wheels to the frame on the rear? Pullin the tire could work but I want to try and get as much meat as I can on the wheels to help with ride quality.
  7. Aug 10, 2012 at 7:35 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ahhhh suck, also when throught your build thread to refresh the memory. Looks like I can run a +35 on the 8" and still clear the fender up front. Not gonna go as low as you just stick with the XR leafs and 4" blocks in the rear and XR bills with stock coils and spacers up front. Should sit it at 4/5.5 and give me plenty of room to run a 45 up front and a 50/55 in the rear....
  8. Aug 11, 2012 at 10:45 AM
    Aw9d
    Aw9d That one guy
    Az
    What the fuck is a Ry Ry?
  9. Aug 11, 2012 at 10:46 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    It's similar to a " Booteen "
  10. Aug 11, 2012 at 11:26 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You gonna be jelly when im mobin mallz on RPF1's before you?
    What pete said, and if you would buy up my double r rear end that will get me closer to being lowerdz
  11. Aug 12, 2012 at 11:47 AM
    Aw9d
    Aw9d That one guy
    Az
    Wife didn't want to swap rear ends on her bike. She's looking at buying a track only bike currently.
  12. Aug 12, 2012 at 4:25 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well thats not helpful
