Pulling 4800 pounds on a trailer with 2012 tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ktm112racer, Oct 12, 2017.
  1. Oct 12, 2017 at 10:34 PM
    Ktm112racer
    Ktm112racer [OP] Well-Known Member
    Hey guys I am wanting to rent a tractor with a tiller for my land and I need to pull it. They said it weighs 4800 pounds total. Is it safe to pull this about 15 miles from the rental place. Will I risk damaging my truck. I have a 2012 Toyota Tacoma double cab 4x4 trd sport with towing package. 4.0 v6. Also if this is ok what's the best way to pull it, like for example is pulling it in just standard drive ok on the transmission?
  2. Oct 12, 2017 at 10:38 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Never tow in 4d
  3. Oct 12, 2017 at 11:12 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    4800lbs is still well below your max load, especially with tow package. Don’t put it in overdrive, put it in the “4” position. You’ll be fine :thumbsup:
    timothom likes this.
  4. Oct 13, 2017 at 3:07 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Is the 4800 lbs the tractor and tiller only or the entire weight including the trailer? If the trailer weight isn't included, then you'll probably be around max weight assuming it's on a steel car trailer. Rentals usually have surge brakes so that part is ok but if you're at max weight and never towed before, I personally would borrow, rent, etc, a bigger truck. Some rental shops will deliver so that could be an option.
    PackCon likes this.
  5. Oct 13, 2017 at 12:02 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This. What is the TOTAL tow weight including the trailer?
    You also need to pay attention to tongue weight. This truck should be close to 600lbs. Dont exceed that.
    This will be a tough job if you have to towing experience. Especially if the trailer is over 10-12ft.
    vssman[QUOTED] likes this.
  6. Oct 13, 2017 at 12:06 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    Screw renting a truck if you have little experience. Get a friend with towing experience to join you and help guide you through the nuances.
  7. Oct 13, 2017 at 12:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It shouldn't be a problem. Especially for 15 miles. I might prefer a bigger truck for a cross country trip.
    randd and Speedytech7 like this.
