Pulling a 5000 lb (dry) weight, 500 lb tongue weight trailer
Discussion in 'Towing' started by IslandGuy, Dec 23, 2011.
  1. Dec 23, 2011 at 9:54 AM
    IslandGuy
    IslandGuy [OP] New Member
    2010 double cab 4X4
    Lear Shell, factory installed towing package
    Hi
    I know there are a lot of threads here on towing but I have not spotted one that really addresses my basic question. I have a 2010 (6 spd manual) double cab 4x4 with the factory towing package and a fibreglass canopy. I am looking at buying an ultralight trailer, 28' 5000lb dry weight, 500 lb tongue weight bullet trailer. We have never towed before. In theory it seems the unit fits into the towing limits but on a practical basis is this a crazy combination? I want a safe, package but mileage and speed are not my real concerns.
  2. Dec 23, 2011 at 10:00 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    At 5000lbs dry, once its loaded with gear and other stuff you may be pushing max towing capacity. Don't know how much your cap weighs but you will definitely be close to GCVWR once loaded with people and other necessities. Me personally, I would look for something a little smaller.
  3. Dec 23, 2011 at 10:07 AM
    YNPFEO
    YNPFEO Active Member
    Yosemite National Park
    05 D-cab 4x4 All-Pro Hybrd bumper sliders
    285/75/16's Mickey Thompson Classic locks, Hella driving lights
    Agree with above......even at 3,800 dry weight my truck does not like it. On the flats its fine, but any hills foget it. If you want a trailer that big consider a full size truck.
  4. Dec 23, 2011 at 12:38 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    Way to big for the taco ... Don't do it friend , get a tundra for that trailer....
  5. Dec 23, 2011 at 7:07 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    This trailer is too much for the Tacoma. You will most likely be over your payload rating. Our trailer is about 3,700 lbs dry weight, with a 440 lbs dry tongue. Loaded for camping and with two adults / two kids in the cab, we were 400 lbs over the GVWR (not GCWR). Don't do it, I guarantee you'll upgrade the truck quickly, especially since you mentioned "safe". Just the area that cross winds will catch will make for some serious white knuckle moments. The Taco has neither the weight, nor the wheel base to keep a trailer like that from swaying, even with sway control.
    Listen to us, don't do it. I know, I have a fullsize truck on order because I did not listen, and our trailer is a 19 ft, 3,700 lbs (empty) trailer, it was 4,300 lbs loaded.
    One more thing: backing that trailer up a hill into a camping spot while turning 90 degrees will eat your clutch in no time. The problem is our high reverse gearing. I have driven manuals only all my life, but backing the trailer up a hill without burning the clutch was nearly impossible with the Taco. Your trailer would be 1,500 lbs more, at least.
    Somebody suggested the Tundra. I wish that would have been a choice, but even with the Tundra, I'd be over the payload with our 19' trailer. A crew cab 4x4 Tundra has pretty much the same low payload as my 4x4 DC Tacoma. Weird, I know .... and a shame. I really wanted the Tundra.
  6. Dec 24, 2011 at 7:02 AM
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    The trailer is a little big for the taco, you be at the maxium range. Even with the tow rating at 6500lbs it's going to be to big for the truck. You want to be no larger than 80% of the maxium tow rating. You have to take into account the cross winds and hills you wil incounter when towing even with the hitch and sway control.
    I'm towing with a 06 DC with factory tow package, brake controller, WDH with no sway control (because the type of expanable trailer).The trailer is a Hi-Lo towlite brand (the expanable trailer is no taller than the truck when it's in the towing mode) 22 foot towlite dual axle. At 4,000lbs fully loaded with propane and gear (I don't tow with fresh water,I wait to get to the campground for that). I have no problem with any hills I may come to. I tow with the overdrive off and in 4.
    Also, towing mirrors are needed. I wasn't impressed with the options for the taco. I installed Powervision brand mirrors from a 98 chevy (since they don't make them for toyota). I posted the job under "show us your towing mirrors" with the wiring diagrams.
  7. Dec 24, 2011 at 11:10 AM
    sechsgang
    Even if you only tow at 80% of the 6,500# tow rating, many people will be over the GVWR with a DC 4x4, especially if there is more than one person in the cab, and any camping gear / firewood, bikes, etc ...
    If you manage to load everything in the trailer, then maybe ... but still close.
