pulling a/c vents, stereo help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fire931, Oct 19, 2009.
  1. Oct 19, 2009 at 10:09 AM
    Fire931
    Fire931 [OP] Well-Known Member Vendor
    VA
    00 4Runner
    hey guys... i've been searching around and can't seem to find what i'm looking for. i know i've seen it somewhere here before. i'm trying to pull the dash piece that has the two center a/c vents in it. its the piece that goes behind the HU... anyone know where the diagram is on that??? thanks!
  2. Oct 19, 2009 at 10:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  3. Oct 19, 2009 at 10:22 AM
    Fire931
    VA
    00 4Runner
    hahaha... was getting ready to give ya all kinds of rep.. but since i have to sift through and find the right section you just get a big :thumbsup: and a thanks... :p
  4. Oct 19, 2009 at 10:34 AM
    Fire931
    VA
    00 4Runner
    well shit... according to that its 10 clips that hold it in place once the HU has been removed... must be some dang strong clips... i yanked the heck outta that thing and it didnt budge...
  5. Oct 19, 2009 at 11:56 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    yea, its just those yellow clips that hold the other dash pieces together...but they are hard to get out. if you break it, i do have a replacement i'll let go for $45 though, so pull away!!
    also note, from what i recall, you have to remove the side trim pieces on the left (the cluster surround and piece below) as those overlap the surround on the left side...make sense?
  6. Oct 19, 2009 at 4:06 PM
    Fire931
    VA
    00 4Runner
    gotcha.. thanks for the heads up...
  7. Oct 19, 2009 at 6:27 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    just doubled checked the surrounds i have, you do need to remove the trim to the left of the surround as there is a lip the entire length of the piece.
