Pulling Aliner camper with 4 cylinder
Discussion in '4 Cylinder' started by Olddaddy, Jul 29, 2009.
  1. Jul 29, 2009 at 3:56 AM
    Olddaddy
    Olddaddy [OP] New Member
    Joe
    North Ga Mountains
    Black Access Cab-4 cyl/auto
    Old owner of new Taco Access cab with 2.7/auto. I want to buy an Aliner pop- up camper. Has anyone pulled one with 4 cylinder auto? Camper weighs about 1500 lbs dry.
  2. Jul 29, 2009 at 3:56 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    i can't help you but i would like to see some pics!
  3. Jul 29, 2009 at 4:17 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  4. Jul 29, 2009 at 5:14 AM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    It will pull it, getting it going is not as much of an issue as stopping it. 1500lbs is pretty light.
  5. Jul 29, 2009 at 12:17 PM
    DrewNJ
    DrewNJ Member
    Doug
    Marlton, NJ
    You will be fine. I pull a double jetski trailer with 2 800lb ski's on it. Total weight of about 2000lbs quite a bit. It's a bit slow to get going and takes a bit longer to stop but nothing you wouldn't expect...
    Good Luck
    Doug
  6. Jul 29, 2009 at 12:39 PM
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Cruise Control, Fog Lamps, Tonneau Cover, KYB Shocks, ScanGauge II, AFE ProDry, Prodigy Brake Controller
    I pull a 2008 Aliner Scout with my 05 2.7 Prerunner. In 4th it will pull most freeway grades with the cruise set at 70 and still get between 17 and 20 mpg. Some really steep grades you have to downshift to 3rd.
    The Prerunner has a 4.10 axle so it's pretty easy to start out.
    My Aliner is all electric. Fridge, hot water heater, microwave, heat. I have a Prodigy brake controller. Tows very stable - no sway.
    Only problem is that I don't get to use it enough! Gonna retire a three or four years and hope to use it much more.
    Bob
  7. Jul 29, 2009 at 7:36 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    It'll tow that no problem. Your truck is rated to tow 3500 lbs, so you're WELL within that. I tow a boat that weighs 1000 lbs more than what you're talking about with my reg. cab 2.7L 5-speed manual - and it handles it just fine. Go for it.
