Pulling apart dash soon - any jobs I should do while in there?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kozy, Jul 31, 2024.
  1. Jul 31, 2024 at 1:23 PM
    kozy
    kozy [OP] Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    Within the next few months I'll be pulling apart the majority of the dash in my 06 to do a few jobs:
    • Replace lower center dash piece with gen 2.5 dual cig lighters/switch slots
    • Change gauge cluster bulb colors
    • Replace problematic air vent tube
    Is there anything else I should look at doing while I have everything pulled apart? Any recommendations for preventative maintenance or nice-to-have upgrades to do before getting everything back together?
  2. Jul 31, 2024 at 1:28 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Don't know if it matters to you, but when I took the dash out of my 3rd gen, I attached two layers of denim batting under the dash. Said different, on the other side of the top flat part of the dash and it reduced engine noise and made longer highway trips nicer.
    kozy[OP] and 2015WhiteOR like this.
  3. Jul 31, 2024 at 1:42 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Inspect/replace your cabin air filter. Check the connectors at the blower motor and the A/C controls for any overheating (brown/black marks). Change every bulb you come across to LED.
    kozy[QUOTED][OP] likes this.
  4. Jul 31, 2024 at 3:24 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Change the gauge cluster plastic cover if yours is scratched. It's like a $20 part.
    deanosaurus and kozy[OP] like this.
  5. Jul 31, 2024 at 3:47 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Clean out the vents that are for defrost. alot of stuff gets in there and may jam the doors.
    kozy[OP] likes this.
  6. Jul 31, 2024 at 5:23 PM
    kozy
    Tim
    Arizona
    What type of batting did you use? the thicker stuff meant for house walls or was it thinner than that?
  7. Jul 31, 2024 at 5:24 PM
    kozy
    Tim
    Arizona
    Thank you all for the great ideas!
  8. Jul 31, 2024 at 6:01 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
  9. Jul 31, 2024 at 11:29 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I didn't like both power ports (cig lighter) being the same as I always had an adapter plugged into one of them. I swapped one of them for built in USB and USB-C ports. It also has a LED battery monitor on it. I also considered running separate "always on" wiring directly from the battery to one of the ports, which would also increase the available power instead of the limited 120w combined power available.
  10. Aug 1, 2024 at 4:15 PM
    hr206
    Western Washington
  11. Aug 3, 2024 at 1:41 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    New heater core for sure.
  12. Aug 3, 2024 at 2:10 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    If he's going that far might as well replace the evaporator too.
