Pulling EFI fuse to deter theft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoGlenn, Nov 2, 2014.
  1. Nov 2, 2014 at 4:41 PM
    TacoGlenn
    TacoGlenn [OP] Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    Firstly, I've searched TW and haven't been able to find anything discussing this, if anyone knows of an existing thread, please direct me.
    I was wondering if pulling the EFI fuse would be a good method of deterring theft, especially in situations were the Taco would be left unattended for extended periods of time (like remote trail heads). One forum suggests that while this might be possible, one poster also notes "..the thief knows about it they don't need to carry extra fuses, the fuse box is full of fuses they could swap in."
    http://www.yotatech.com/f2/poor-mans-theft-protection-what-fuse-do-i-pull-74085/
    This guy has a neat trick to possibly disguise the pulled fuse idea: http://www.youtube.com/watch?v=GolUQCblm0I
    A poster on another site states- "Take into consideration the harm done to the contacts in the fuse box,they need to maintain tension on the fuse, they are not made to have there fuses removed several times a day, I have repaired fuse boxes when the failure was poor contact due loss of tension." http://community.cartalk.com/discussion/1976809/which-fuse-to-remove
    Someone else suggested pulling some fuses would cause a problem with the ECMs memory loss: Anyone try this or have opinions?
    I realize I could install a hidden fuel pump kill switch (is there a mod for this on TW? I couldn't find one), but I thought pulling the fuse would be easier.
  2. Nov 2, 2014 at 5:00 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    you probably want a kill switch.
  3. Nov 2, 2014 at 5:14 PM
    el tardo
    el tardo Well-Known Member
    my two cents-
    if someone wants your truck let them have it,thats why we have ins.what will happen is they will destroy your truck cause they couldnt steal it.
    outlawtacoma likes this.
  4. Nov 2, 2014 at 6:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I like this idea!
  5. Nov 2, 2014 at 6:02 PM
    anotherreject
    anotherreject Well-Known Member
    +1 for a hidden kill switch, it will turn into a pita to pop the hood and take out/replace the fuse every time you use the truck.
    the majority of car thieves would pass over your car with a visual deterrent, like a old style steering wheel lock.
  6. Nov 2, 2014 at 7:03 PM
    Bucc5207
    Bucc5207 Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
    What about the immobilizer? Or does it not actually work? :confused:
  7. Nov 2, 2014 at 8:19 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    Honestly, this is the first vehicle I've owned in 20 years, so I'm not familiar with how the immobilizer works or how effective it is. Can thieves bypass it?
    (My last truck was a '74 Chevy; I could remove the rotor from the distributor in a similar long-term unattended scenario)
  8. Nov 2, 2014 at 8:32 PM
    nd4spdbh
    SoCal
    nothing wrong with an added layer of protection if the truck is sitting for a while.
  9. Nov 2, 2014 at 8:36 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
  10. Nov 2, 2014 at 11:34 PM
    Bucc5207
    Yrisarri, NM
    2014 V6 SR5 4x4
  11. Nov 3, 2014 at 2:02 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    No disrespect to the gentleman in the video but that seems a little over kill. If you are going to all the trouble to raise the hood, open the box, short out a fuse, and switch fuses with one that does not work, why not just remove the one good fuse and leave it out?
  12. Nov 3, 2014 at 2:16 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I don't know if pulling the fuse will do any damage, besides maybe the suggested loosening of the tension.
    Personally, I'd use a deterrent rather than this. If a pro wants it, they'd Ofigure it out or more than likely tow it. The average thief won't mess with a steering will lock. Takes to much time. But hear is a kill switch write up if you want to.go that route too.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/88252-kill-switch-mod-write-up.html
    I personally wouldn't feel comfortable pulling the fuse constantly.
  13. Nov 3, 2014 at 2:39 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Wheel the truck and bang it up a little. 's the best way to deter theft. That or park next to a truck that's nicer then yours. :cool:
    I do that all the time on my motorcycle. People aren't going to steal my ratty dual sport over the chromed out Harley I'm parked next to.
    agunday21 likes this.
  14. Nov 3, 2014 at 3:27 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    A Tacoma with the 2.7 litre or 4 cylinder engine DOES NOT have the engine immobilizer. Toyota in their infinite wisdom decided to save money and not have an immobilizer system for the 4 cylinder model. ONLY the V6 equipped Tacoma will have the immobilizer system.
    It is a bit of good and bad for a 4 cylinder Tacoma owner, you can replace an ignition key real cheap, but your truck has no theft protection.
  15. Nov 3, 2014 at 4:38 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    What you could do is install a SPDT relay with the starter wire connected to the normally open contacts. You would then activate a switch (high beam, turn signal, etc.) in the vehicle to activate the relay allowing the truck to start.
    I did this to my friends Honda Accord and a week later someone tried stealing it and couldn't. They did mess up the ignition cylinder tough.
  16. Nov 3, 2014 at 8:39 AM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    I think his reasoning is having the bad fuse in position might be less obvious to a thief than no fuse in position.
    I wasn't considering this on a regular basis, just those few times a year when I go back county for a few days at remote trailheads. Thanks for the heads up on the mod!
    I didn't know that! I have the 2.7.
    Yes, I did see this suggestion on other forums, thanks.
    Thanks all for the responses!
  17. Nov 3, 2014 at 9:48 AM
    Bucc5207
    Yrisarri, NM
    2014 V6 SR5 4x4
    I did not know that!
    It's easy to tell, anyway. If you have a flashing red light on your dash (mine is under the radio, next to the clock), that stops when you insert your key, you have the immobilizer system.
  18. Nov 8, 2014 at 12:35 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    I have no blinking light. My 2011 did.
  19. Nov 8, 2014 at 1:15 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Hide a toggle switch with an inline fuse socket. Put two blade terminals on the end of the wires. Pull the fuse, plug in the blade terminals, and plug the fuse into the inline socket. Flip the switch to disconnect the juice withou having to pull fuses. For the really creative types, a stock looking switch in one of the blank panels would hide the cutoff in plain sight...
  20. Nov 9, 2014 at 7:28 PM
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    Still can't find a DIY hidden fuel pump kill switch mod on TW; strange, with all you mod-happy folks out there I thought there would surely be one.
