Pulling motor 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigbuck1999, Jan 24, 2020.
  1. Jan 24, 2020 at 8:25 PM
    Bigbuck1999
    Bigbuck1999 [OP] Well-Known Member
    1996 Tacoma, 2017 TRD off road
    Guys I’m going to be doing an engine swap in my 96. Just a quick question here for those who have done this. I’m not seeing anywhere to hook a strap or chain up top to pull the motor. Am I missing something? How did you guys do it, what’s safe to really hook around??? Thanks
  2. Jan 24, 2020 at 11:12 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    you can buy the engine hooks from the dealer or do what I’ve done before which is take off the upper and lower intake plenum and lift out the engine by bolting the chain to the intake manifold.
    Area51Runner and cruiserguy like this.
  3. Jan 24, 2020 at 11:22 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    one hook is already on the engine (unless some on removed it) on the driver side
    the other hook is sold at the dealer. its not too expensive. it goes where the power steering pump is. Buy it, it makes leveling the engine 10X easier
    or you can bolt to the manifold like stated above.
  4. Jan 25, 2020 at 3:39 PM
    Glamisman
    Glamisman Well-Known Member
    while she is out take a good look, a VERY good look at the exhaust crossover between the cylinders. In later model Tacomas replacing this is ok, on the 96 it is just different enough and is difficult. At the same time pop the flywheel off and the separator plate and look at the core plugs in the block while you are there.
