pulling out a stuck vehicle..any danger from doing it in reverse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Jan 30, 2010.
  1. Jan 30, 2010 at 7:29 AM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i did a search, and found very little. i used to pull everyone out, when i lived in texas. recovering my little bro's early bronco, with my 1984 POS jeep cherokee was a highlight. i did alot in reverse. helps to see, hooks were up front, etc. even pulled some stumps in reverse.
    is it bad for our tacoma trannies to yank in reverse?
    N-C.nebulosus likes this.
  2. Jan 30, 2010 at 7:33 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I believe so. I have read on here somewhere that they said it was. I think you get a lot more power pulling forward too
  3. Jan 30, 2010 at 9:48 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    From what I have heard and read over the years, it's not a good idea to pull in reverse. I believe the issue is the gears in the diffs and the strengh of them when in reverse.
    Marc M
  4. Jan 30, 2010 at 10:00 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I also have heard that recovery is easier on the running gear while in forward gears. That said however, I have done several recovery tows in reverse before knowing the difference and haven't seen any negative affects thus far - but won't chance it again if I don't have to.
  5. Jan 30, 2010 at 10:15 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    Pulling forward is using a lower gear ration. In my 2009 auto the first gear ration is 3.53 and the ratio for reverse is 3.22.
  6. Jan 30, 2010 at 10:19 AM
    Twiget
    Twiget Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    Besides damaging the tranny, what about tearing up the front end? The rear axle is built to handle the extra forces of hauling a 1/2 ton of crap as well as towing or pulling someone out of the mud. What about the front end though? Its got to be pretty stout to survive being pulled out of the mud itself, but its not nearly as heavily sprung as the rear end.
  7. Jan 30, 2010 at 10:22 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have made tons of recoveries in reverse. However I never jerk or jar anything in reverse. If its a simple pull I would do it but with any difficult recovery I go in forward.
  8. Jan 30, 2010 at 10:23 AM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Not related to tranny...I think what's bad when doing it in reverse is if it snaps, the hook or strap can go straight right at you.
  9. Jan 30, 2010 at 10:41 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I was always told the reverse cut gear is thinner thus weaker so when ever possible pull forward
  10. Jan 30, 2010 at 10:52 AM
    Toymaker
    Toymaker Well-Known Member
    DC
    2013 Tundra RCSB 4x4 TRD OR, Black
    The gearing and combination parts that a transmission uses in reverse, compared to forward gearing, are generally less rubust and are unsynchronized. It's perfectly adequate for the short periods of operation that your vehicle is used in reverse but, for pulling loads, it should be avoided unless absolutely necessary.
  11. Apr 30, 2012 at 8:47 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Sub'd
  12. Apr 30, 2012 at 8:50 AM
    DWreck
    Derek
    Las Vegas, NV
  13. Apr 30, 2012 at 8:57 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just from the standpoint of protecting the gears,yes but pushing from the front end has it's own pitfalls. The front isn't as strong as the rear because of the IFS components. But parking a trailer is MUCH easier when it's hooked on the front of the truck :)
    For a simple pull, I wouldn't hesitate to to pull in reverse (or reverse a heavy trailer). If the vehicle is really stuck and you'll need to work at it, better off to do it in forward.
  14. Apr 30, 2012 at 8:58 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    You arent backing that trailer over a bunch of rocks or through axle deep mud. Just a tad bit of differance in the amount of force generally being used there....
    But pushing a trailer like that would make it a lot easier in tight spots. Handy little setup.
  15. Apr 30, 2012 at 9:00 AM
    Pugga
    Massachusetts
    Yep, thread revival FTW! Even in the 2nd Gen section and everything :bananadance:
  16. Apr 30, 2012 at 9:04 AM
    CrackerJackMack
    CrackerJackMack First class awesome
    Kevin
    Dallas, TX
    10 4x4 SR5 TRDoff
    nm, necro poster !
  17. Apr 30, 2012 at 9:10 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Old thread but info should be here.
    Reason why you should never pull vehicles in reverse is that when you doing so you using coast side of the R&P which is weaker.
  18. Apr 30, 2012 at 9:16 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  19. Apr 30, 2012 at 9:17 AM
    CrackerJackMack
    Kevin
    Dallas, TX
    10 4x4 SR5 TRDoff
    Only if you are slamming on the skinny pedal going up a hill or through the mud ;)
  20. Apr 30, 2012 at 9:22 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well no, if you are driving like a moron the whole equation changes.
