pulling out a stuck vehicle..any danger from doing it in reverse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Jan 30, 2010.
  1. Apr 30, 2012 at 9:23 AM
    CrackerJackMack
    CrackerJackMack First class awesome
    Kevin
    Dallas, TX
    10 4x4 SR5 TRDoff
    Or trying to get someone unstuck.... just say'n..
  2. Apr 30, 2012 at 9:24 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Why do they put tow hooks on the front then and not the rear? I am too interested!
  3. Apr 30, 2012 at 9:30 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    For getting pulled out by the guy that knows how to drive. :cool:
  4. Apr 30, 2012 at 9:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :laugh:
  5. Apr 30, 2012 at 9:31 AM
    CrackerJackMack
    Kevin
    Dallas, TX
    10 4x4 SR5 TRDoff
    +1 For you sir
  6. Apr 30, 2012 at 9:37 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    The tow hooks on the front are intended to pull your truck out.
    I however, do retrievals for the off-road races in the area. I pull trophy trucks and class 1s out of sticky situations often. If it's stuck in silt, I usually back up to it and pull it forward. But rollovers, I prefer to attach to the front and reverse when flipping them over. Better vantage point and easier to tell when the vehicle is about to fall, so I know when to quit pulling. I've pulled several "broke" cars off course with the front as well. I do it conservatively, and try not to yank aggressively. It really comes down to your discretion. If pulling in a forward gear is conceivable, do so. If it is a tricky pull, and you need to see what is going on, pull from the front. It may even come down to safety. Again, use your discretion. End story.....lol
  7. Apr 30, 2012 at 1:01 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    this is a very good point
  8. Apr 30, 2012 at 1:11 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There is danger in recovery pulls in reverse. There is also danger in recovery pulls with a forward pull. Using ones brain can minimize the danger considerably. Listening to that "spidey sense" that says "its a bad idea" goes a long way.
    As far as danger fron a broken strap, etc, the front windsheild offers much more safety that the non-reinforced back window, but putting a heavy jacket on the strap will reduce rebound in either case. Point #1 also applies, use a big enough strap, and keep it in good condition.
    The transmission would be one of the last things on my worry list, especially since you should be in 4lo. I wouldn't be worried about the R+P specifically in reverse either, while it is possible to shock load the gears and break teeth in either direction, they are not somehow weaker in reverse. Solid axle 'yotas run on the front diffs on the reverse drive side, always have.
    My biggest concern is the lack of strong front recovery points on stock tacos, other than MAYBE the trd o/r tow hook. I can't say for sure, as I haven't seen one in person.
