Pulling out a tree stump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, May 31, 2017.
  1. May 31, 2017 at 7:29 PM
    #61
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    :spy:
    Similar issue so sub'd for results!
  2. May 31, 2017 at 7:35 PM
    #62
    69others
    69others Well-Known Member
    You would not believe how strong the smallest of roots can be in holding back a truck 2x the size of a taco.
    Been there done that.
    Chop as many roots as you can. Its not a bulldozer.
  3. May 31, 2017 at 7:35 PM
    #63
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Meh. It isn't the left shoe. So I'm no longer concerned. :rofl:
  4. May 31, 2017 at 8:57 PM
    #64
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    shovel pick and axe should do the job in about 20 minutes or so... Or look in your owners manual in the "Stump removal section"
  5. May 31, 2017 at 9:48 PM
    #65
    scw156
    scw156 Well-Known Member
    PA
    2016 DCLB Off-road MGM
    I pulled out the stump of a Japanese maple last summer. No problems.
    Edit: I'll note that I took time to chop roots then dug down under the stump and put the chain down under as well as around. Came right out smooth.
  6. May 31, 2017 at 9:57 PM
    #66
    TacoLand
    TacoLand Well-Known Member
    With gasoline...
  7. Jun 1, 2017 at 5:24 AM
    #67
    Hammer16
    Hammer16 Well-Known Member
    Western MA
    2016 Quicksand Tacoma DCLB TRD OR
    I have done about a dozen stumps with my 3rd gen. About 4 of them were similar size. As others have said, it will help big time if you can dig a bit and chop some roots. Also, DO NOT use a chain. If the chain slips or god for bid breaks, that's a lot of flying metal to do damage. Use a heavy tow strap or Bubba Rope. Truck likely can do it as long as you can get good traction.
    Tom Servo likes this.
  8. Jun 1, 2017 at 5:38 AM
    #68
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I used a hi-lift jack to pull out a stump. Worked out well.
  9. Jun 1, 2017 at 6:18 AM
    #69
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    You need leverage if you are going to pull it out in the vertical position if you are going to use truck to pull in the horizontal position. I've seen old wheels, large logs (size of the height of hitch point) or you can rig up a thick piece of wood at 45 degrees but would need an anchor point at the bottom end.
  10. Jun 1, 2017 at 6:34 PM
    #70
    3rdGenTacoDad
    3rdGenTacoDad Active Member
    2016 DC SB TRD Off-Road
    Here's the one with the stump flying through the rear window
    Nedrolls likes this.
  11. Jun 1, 2017 at 6:50 PM
    #71
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Well looks like have something else to look forward to this weekend. :mudding:
  12. Jun 1, 2017 at 6:52 PM
    #72
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Did it with my first gen and the stump went air born smashing into my tail gate. Take it slow and it will pull it out no problem.
  13. Jun 1, 2017 at 7:04 PM
    #73
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    OP do you own a sawzall? They make short work of roots.
  14. Jun 1, 2017 at 7:55 PM
    #74
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    I'd recommend using a couple of cable dampeners in case the strap or a heavy blanket if the chain breaks in half.
  15. Jun 1, 2017 at 8:16 PM
    #75
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Way too much good advice. You are ruining this thread for the rest of us.
  16. Jun 1, 2017 at 8:30 PM
    #76
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Not with that attitude
  17. Jun 1, 2017 at 8:40 PM
    #77
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Omg....just pull that thing out already! 5 minute job
  18. Jun 1, 2017 at 8:47 PM
    #78
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    Deforestation... fuck yeah!!! *Because nature dont know sh!t.
  19. Jun 2, 2017 at 1:56 PM
    #79
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Id WD-40 that bitch overnight before trying to pull that out :)
    jamonsote likes this.
  20. Jun 2, 2017 at 2:07 PM
    #80
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    :rofl:
