Pulling the Front Seats
Discussion in 'Detailing' started by Scott K, Feb 1, 2010.
  1. Feb 1, 2010 at 9:54 PM
    Scott K
    Scott K [OP] Well-Known Member
    Scott
    Coquitlam, BC, Canada
    Amsoil Synthetic ASL 5w30 Oil, Amsoil ATL Fuel Efficient ATF, Amsoil Severe Gear 75w90 in front/rear diffs & transfer case.
    I am want to pull the front seats (unbolt them, take them out of the vehicle) so I can give the carpet underneath a serious once over since the previous owner didn't seem to care what they put under the seats apparently. Now this truck has seat air bags if I'm not mistaken, so is there anything I need to do or know before I unbolt the seats to do this?Is there some kind of connector I need to undo or anything I need to watch for? Thanks...
  2. Feb 1, 2010 at 9:57 PM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    Un-hook the battery and then when you are pulling the seat you should see the plug.
  3. Feb 1, 2010 at 9:58 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    yes, even my 08 double cab which does not have seat airbags has some electronics connected underneath. These are the electronics to the seat belt pressure sensors (it senses your weight then starts beeping if your belt is not on). You will see a clip where these can be released, then you will be able to take out your seats.
  4. Feb 1, 2010 at 10:12 PM
    Byrd32
    Byrd32 "Don't touch it. Don't even look at it."
    Nick
    Arkansas
    '09 SUPER WHITE
    Tinted windows, 3" Lift, Bull bar, Black Center Caps, Weathertechs, Painted Grill
    So, if wanted that annoying beeping to stop all i would have to do is unhook that clip!??
  5. Feb 1, 2010 at 10:14 PM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
  6. Feb 2, 2010 at 5:50 PM
    Byrd32
    Nick
    Arkansas
    '09 SUPER WHITE
    Thanks Mondwa! It worked!
  7. Feb 2, 2010 at 5:57 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Undo the four bolts tilt seat back. Unplug the connectors being careful not to punch yourself in the eye! One of them was real stubborn. As was mentioned earlier disconnect the battery first.
  8. Feb 2, 2010 at 6:16 PM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    Good deal , glad to help
