Pulling to the Left...
Discussion in 'Suspension' started by NLF, Jan 18, 2011.
  1. Jan 18, 2011 at 5:54 AM
    NLF
    NLF [OP] Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    Just installed the 5100s at 1.75 in the front, and new XD Revolver rims (17x9) with the stock 265/65/17 BFG Rugged Trail tires on Friday. Had a local shop install the 5100s, and they had a hard time getting them in. Finally dropped the lower arms to get them in easier.
    Had it aligned on friday, pulling to the left. Took it back in monday after about 100 miles and had it re-aligned. Everything looks good on the machine.
    However, it is still pulling to the left. Any ideas on what the heck could be going on? It goes to Toyota on Friday for the rear TSB leafs, maybe they can adjust something to make it right. Just looking for anyone with past experience.
    Thanks.
  2. Jan 18, 2011 at 6:40 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    post up your alingment #'s
  3. Jan 18, 2011 at 7:35 AM
    NLF
    Levi
    Minneapolis, MN
    I don't have them. I watched them do it, and it was right to specs yesterday morning. Still pulls to the left though, as I just drove 700 miles back to MN.
  4. Jan 18, 2011 at 8:33 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea without #'s there is not much help......
  5. Jan 18, 2011 at 9:24 AM
    NLF
    Levi
    Minneapolis, MN
    Ok, I was just checking to see if it was another issue other than alignment.
    It is going to Toyota on Friday, they will look at it.
  6. Jan 18, 2011 at 9:25 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    good luck keep us posted
  7. Jan 26, 2011 at 6:05 AM
    NLF
    Levi
    Minneapolis, MN
    Originally:
    Camber - Caster - Toe
    Front L- .5 / 1.9 / -.09
    Front R- .2 / 2.1 / .05
    Front - .4 / .1 / -.03
    After Toyota Dealer Alignment:
    Front L- .5 / 1.9 / .03
    Front R- .2 / 2.1 / .03
    Front - .4 / -.1 / .06
    Truck feels great, but still pulls to the left. Toytec recommended swapping the wheels on the front to see if that fixes it.
    Ideas???
  8. Jan 26, 2011 at 6:10 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    try and get them to even up that caster and rotate the tires
    but have them even up the caster 1st then test dr it
  9. Jan 26, 2011 at 6:14 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    here are my #'s
  10. Jan 26, 2011 at 6:17 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you can try swaping wheel sides.....
    if your tires are evenly worn i supoose that could cause some pulling issues..
    its worth a shot.....
    your # dont look too bad your caster could be a lil higher and you really want your toe at or as close to 0 as possible.....
    but without aftermarket uca's that might not be possible.....
    swap the tires and see how it fells....
    thats the most important thing.....
    try diff road surfaces alot of the roads today have a crown to them and are in neglect n have settled n such
    just a thought
    g/l
  11. Jan 26, 2011 at 6:23 AM
    NLF
    Levi
    Minneapolis, MN
    My truck only has 2500 miles on it, so I would assume the tires are fine. I am going to try the switch, and see how that goes.
    I am only at 1.75" on my 5100s, sucks to be having issues as I figured this was pretty bullet proof.
  12. Jan 26, 2011 at 6:30 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    listen to david he is the master.....
    he did mine.....
  13. Jan 26, 2011 at 6:31 AM
    David Tarantino
    N.J.
    08 tacoma
    thats a damn good looking alignment who did that:D
  14. Jan 26, 2011 at 6:33 AM
    David Tarantino
    N.J.
    08 tacoma
    have them re do the alignment and set the caster to 2.1 on both sides
    keep me posted
  15. Jan 26, 2011 at 11:31 AM
    NLF
    Levi
    Minneapolis, MN
    Swapped the tires over lunch, problem solved. Only question is will a future rotation cause the same issue?
  16. Jan 26, 2011 at 11:35 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    it shouldnt
    it might have been a lil out of alingment before the 5100's and now you should be good to go
  17. Jan 26, 2011 at 11:36 AM
    NLF
    Levi
    Minneapolis, MN
    Thanks for all the help, I'll post pics of the truck no that it is settled.
  18. Jan 26, 2011 at 11:37 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :thumbsup:
    :thumbsup:
  19. Jan 26, 2011 at 11:49 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    These are my numbers from my last alignement.
    The first alignement I had done after my 5100's were put on.
