Pulling to the right while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ward3232, May 26, 2019.
  1. Jun 12, 2023 at 3:39 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Ok I didn't read everything.
    This is my rule. It has served me well.
    Replace everything in pairs.
    You would not buy one new shoe, keep both sides the same.
    Also, you said your pulling started after pad replacement.
    You found brake fluid.
    I have seen the brake lines (rubber) looped/twisted after pad install so many times. Then they rub against themselves, and blow a big rubber bubble when you use the brakes, then they will break.
    If you are seeing wear on a rubber brake line, replace both of them.
    Get a new caliper for the other side.
  2. Jun 12, 2023 at 6:08 AM
    Waasheem
    Waasheem
    2007 xrunner
    Absolutely this. Brake friction material will absorb brake fluid. Once that happens the correct thing to do is replace.
    Before the new pads go in clean the rotor thoroughly.
  3. Jul 2, 2025 at 3:15 PM
    sergio135
    sergio135 New Member
    Hi all,
    I have the same problem with my truck, it pulls to the right when I press brakes, I already
    Changed the calipers, pads, rotors.
    rear brakes.
    the inner and outer rods, and I noticed today that the upper control arms are moving a bit, can this cause the truck to pull to the right when I press brakes?
