pulling to the right...
Discussion in '5 Lug' started by Joels98taco, Mar 16, 2012.
  1. Mar 16, 2012 at 7:58 PM
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    ok so i just put new ball joints ball joint brackets and new aal on my truck. took it down and got it aligned and its pulling to the right. is the alignment off? the steering wheel is straight and the tires look straight. any idea what it could be? the brackets are custom made by me and are super close if not exactly the same on both sides. im thinking maybe the axle shifted? maybe the leafs have differemt lengths? im stumped and it bugs the shit out of me :mad:
  2. Mar 16, 2012 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like the alignment is off.
  3. Mar 16, 2012 at 8:00 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    could be alignment, did you notice any vibrations?
  4. Mar 16, 2012 at 8:02 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    thats what im thinking maybe they half assed it. no vibes i noticed. the wheel shakes but im sure the tires are out of balance. should i take it back and say wtf fix it?
  5. Mar 16, 2012 at 8:56 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Check tire pressure
  6. Mar 16, 2012 at 9:28 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    on my way to check now what could the tire pessure have to do wit it?
  7. Mar 16, 2012 at 9:35 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    If you've got a low tire, the vehicle will pull to that side. Front is more noticeable. You could try to go back to the shop and say hey this thing is pulling to the right, fix it. The shop should have done the tire pressures. They shouldn't have let it go if it was pulling.
  8. Mar 16, 2012 at 9:37 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    d side had 28 rear 29 front p side had 28 rear 30 front aired down to 29 could the 1 pound make a difference?
  9. Mar 16, 2012 at 9:38 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    thats what im thinking why did they say its ready if the guy test drove it and everything but it pulled to the right and at any speed :( and is bad enough to where you have to hold it slightly to the left for it to drive straight
  10. Mar 16, 2012 at 9:41 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    do you guys think maybe the axle didnt center right on the pins on the leafs?
  11. Mar 16, 2012 at 9:49 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    i bolded and italicized the wheel shakes because if it does that than your tires need to be balanced, this is typical. which explains the pull to the right..
  12. Mar 16, 2012 at 9:51 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    the wheel has shaken since i got the tires put on then i did the spindles and aal and got it aligned. straght as an arrow and the wheel shook. it would have done it then too right?
  13. Mar 16, 2012 at 10:00 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    yes and no as you raise the truck farther off the groung the more "feel" you will have therefore your truck center of gravity will be higher. your tires will move with the road more....
  14. Mar 16, 2012 at 10:17 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i drove it lifted a good year before i did the ball joints up front and just now started pulling
    im gonna try to take it down tomorrow and see what happens
  15. Mar 16, 2012 at 10:18 PM
    LAoffroadin
    Joshua
    Northwest
    2012 offroad 4x4
    well thats beyond my understanding there brotha!!
  16. Mar 16, 2012 at 10:21 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i think its the arms.... time for LT :D
  17. Mar 17, 2012 at 1:01 AM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    Damn^ always pushing the LT LOL
  18. Mar 17, 2012 at 1:20 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Haha I know right? :D
  19. Mar 27, 2012 at 1:37 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    anyone think it could be a bad wheel bearing?
  20. Mar 27, 2012 at 9:16 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Check the rear u bolts for tightness, but I'd guess it needs balanced or realigned
